Author Topic: 2 Pin Flasher replacing a 3 Pin  (Read 2683 times)
jonathanrowley
« on: April 25, 2016, 11:08:09 AM »
I've bought a cheap 2 pin flasher unit rated to drive two Bulbs at 28W. I have no Dash repeater.
Can it be fitted in place of the standard 3 pin one which flashes too fast?
It has a B (Battery) and L (Load) Pin only...
Or do I have to find a 3 Pin - searched the WWW but can't quite find the answer...
« Last Edit: April 25, 2016, 11:08:50 AM by jonathanrowley »
Re: 2 Pin Flasher replacing a 3 Pin
« Reply #1 on: April 25, 2016, 11:42:08 AM »
My '81 R65 has a small cafe-ish fairing with streamlined LED turn signals. OEM rear turn sigs. Of course, the lights flasher too fast with the OEM turn signal relay.
A quick trip to the nearest auto parts store got me a five-dollar turn signal 3-pin relay designed for use with these fancy new cars with LED signals out the wazoo. Plug n' play.
« Reply #2 on: April 25, 2016, 09:02:56 PM »
Don't feel too bad about having to buy a 3-pin relay.
I bought 2 of the exact 2-pin type in your photo from a Chinese supplier (I bought 2 because they were so cheap and I thought to have a spare for the KLE and Yamaha, both of which use the 2-pin variety. I also liked the idea of the adjustable flash speed as I am currently converting every bulb I can on the KLE to LED.
Well the first one lasted a day and the second a day short of two weeks. An (at least) 30 year old spare flasher that I found in my "hope chest" is now doing duty on the KLE, it flashes a bit fast, but I'll live with it.
jonathanrowley
« Reply #4 on: April 27, 2016, 07:08:53 PM »
jonathanrowley
« Reply #5 on: May 09, 2016, 12:33:42 PM »
Thanks - it's ordered and on its way
