Author Topic: Weird starter  (Read 1464 times)
Offline Julio A.
Weird starter
« on: April 23, 2016, 02:29:55 AM »
this happened earlier this morning:
I press the starter button while the bike is in neutral. the starter just clicks like mad as if something blocking the engine's rotation.
I kick start the bike, starts up immediately.
I press the starter button again, it just repeatedly clicks again.
I pull the clutch while in neutral, pressed the starter button. I starts right up.
What the heck just happened? Is it a sign of an impending failure of my clutch or transmission?
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Weird starter
« Reply #1 on: April 23, 2016, 03:12:08 AM »
Something is not happy, but more info is really needed.
Pulling the clutch in and it starting perfectly may (and I stress MAY) be a sing of something truly horrid happening that is allowing the flywheel or the ring gear (depending on year) to move in and out.
Equally it could be a sign of no more than a poor terminal somewhere that is bypassed when the neutral inhibit is locked out by the clutch switch.
I'd do two things - firstly remove tank and engine top cover and do a make/break on every terminal blick or cable connector that looks like it might go to the RHS handlebar switchblock or the starter motor.
While i was there I'd disconnect the starter solenoid trigger wire and see what voltage is there when the bike is in neutral and when the clutch is pulled in - if it varies in favour of the clutch scenario, do a make/break on all the connectors from the neutral switch heading north.
if your voltages look OK, then take out the timing bung and shine a torch in there and see if you can see any movement fore and aft. Actually seeing as by now you have the top cover off - look there.
If that all looks OK, then start removing the starter motor. Pull it to pieces, check brishes and shout it a new solenoid (they are cheap, VW ones fit, amongst many, many others. Sometimes the solenoids contacts go bad. Once upon a time you could pull them apart, dress the contacts and reassemble - but not for a very long time. A clean and re-grease of the bendis gear and motor bushes will be appreciated by the starter even though they were probably not the cause.
You will notice maybe that I skipped over something - what to do if you can see fore/aft movement of the flywheel. It is possible, although usually not unless very high miles have been covered, for the thrust bearing/bushes to fail, but this is usually first noticed by the honking geese noise the engine makes while idling as it suck air past the front and rear crank seals.
The firther alterniative if your bike has a clucth carrier is that you may have a beginning failure there. l
Re: Weird starter
« Reply #2 on: April 23, 2016, 03:12:35 AM »
Oh, and BASTARD, you have a kick starter!
Re: Weird starter
« Reply #3 on: April 23, 2016, 10:36:09 AM »
There is an electrical connector on the left side of the bike, in the area around the side cover .
This connector has the wires for the oil pressure switch and the neutral switch .
You can disconnect the connector and use a piece of wire in the socket on the upper part of the connector for the neutral switch and secure it to a good ground, make sure the transmission is in neutral before you do this .
Try the starter to see if this corrects the starter issue .
Offline skippyc
Re: Weird starter
« Reply #4 on: April 25, 2016, 04:28:27 AM »
A clicking starter is a sign of momentary loss of power, depending where the power comes from to operate the solenoid it could be a high resistance connection, as the voltage drops when the starter kicks in there is not a enough voltage to hold the solenoid so it drops out, then it happens over again.
Offline Julio A.
Re: Weird starter
« Reply #5 on: April 28, 2016, 01:55:12 AM »
Found the problem. The 30 year old starter relay was going bad.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
