Author Topic: Front brake light switch  (Read 2366 times)
Offline MikeFossl
« on: April 24, 2016, 03:07:56 PM »
I'm on the road away from my Haynes manual.  Looks like I need a new switch.  How do I remove, fit the switch?  I assume it's threaded but I don't see any lands for a wrench.  Vice grips?
« Last Edit: April 24, 2016, 03:08:55 PM by mikefossl »
1985 R65
Re: Front brake light switch
« Reply #1 on: April 24, 2016, 03:31:17 PM »
I believe the switch screws into the lever perch. It's a coarse thread. Be gentle when attempting to unscrew the switch.
Offline MikeFossl
« Reply #2 on: April 24, 2016, 03:35:57 PM »
Gentle with....vice grips?
1985 R65
« Reply #3 on: April 24, 2016, 03:39:03 PM »
Gentle with....vice grips? :-/
Maybe pliers to more easily control rather than the crushing pressure of the ViceGrip.
Offline Matt Chapter
  • <insert witty remark here>
« Reply #4 on: April 25, 2016, 02:54:44 PM »
Seems like several people have replaced their front brake light switch recently.  When I did mine I did not manage to keep the old one pristine during the removal process.  As long as the threads are clean for installation of the new one, seems ok to me.
'04 R1150 RT ~41000 miles
Offline MikeFossl
« Reply #5 on: April 25, 2016, 09:49:34 PM »
It came off quite easily with a pair of needle nose pliers.  The switch didn't respond to a liberal dose of carb cleaner (all I had) despite leaking plenty of black stuff.  I was able to get to work intermittently but will now have to wait for a new part from the local dealer.
1985 R65
« Reply #6 on: April 26, 2016, 12:45:17 AM »
Depending on what stock the dealer has, or is able to draw from you may find that you need to extend the plastic bit that does the switching somewhat. I found that a section of Biro refill worked a treat.
thrang
« Reply #7 on: April 26, 2016, 05:41:50 PM »
If you struggle to find a switch I can post one as I've got a couple of spares in my box.
