Author Topic: Clutch cable end  (Read 1656 times)
Offline chrisr65ls
Clutch cable end
« on: April 08, 2016, 02:21:41 AM »
I'm removing the left hand switch block to respray it. I've disconnected the clutch at the gearbox but can't work out how to get the end of the cable (with the stopper on it) free of the switch block (on the handle bars). Am I supposed to pull it all the way through or something. There doesn't seem to be a grove for it to slide out of and i'ts too big to :( go back through the back of it.
Re: Clutch cable end
« Reply #1 on: April 08, 2016, 06:07:02 AM »
You will find that the handlebar end of the cable is contained inside a removable ferrule. First turn the adjuster and its locknut so that the grooves in them face forward, you will then be able to pull the casign back out of the adjuster and then bring the cable itself out along the now exposed groove in the perch. When the end og the cable comes loose the containing ferrule will either stay inside the lever or will fall on the floor - do not let either happen.
if you lose that ferrule you will not be able to make the clutch operate properly and you will have to then wait until the one your order from your supplier of choice arrives.
Why did BMW set the cable up that way. Well it is just possible that with the additional ferrule in place your cable will last a little longer than it otherwise might. Or it could be just because they could.
Don't lose the ferrule.
Offline Matt Chapter
  • <insert witty remark here>
« Reply #2 on: April 08, 2016, 11:20:35 AM »
Alternatively, you could be completely unaware the ferrule (I think BMW calls it a nipple?) exists, and slip the cable end directly into the lever.  This will probably work for a while, until the lever wears through and then has a raw edge that cuts every clutch cable you put on.
Theoretically.
'04 R1150 RT ~41000 miles
« Reply #3 on: April 08, 2016, 07:59:27 PM »
Theoretically.
I like your theory.
Have met more than one BMW rider who did not know that the nipple (you are correct) was needed and could not understand why their bike had a "difficult" clutch action and ate cables.
Offline chrisr65ls
« Reply #4 on: April 08, 2016, 09:03:10 PM »
Got it. Thanks Tony! ;)
« Reply #5 on: April 08, 2016, 09:04:50 PM »
Chris, you are local to me. If you need a hand, just ask
« Reply #6 on: April 08, 2016, 10:14:17 PM »
I may be dumb but I'm not stupid. After the second clutch cable I figured out what was missing.  :D
« Reply #7 on: April 08, 2016, 11:17:04 PM »
I think that at some stage we have all done dumb things, I'll tell you one day about the really, really loud tappet rattle that resulted from installing the rocker shafts upside down on my R100. Fortunately new shafts/axles are not too expensive and I had lots of stuffed bearings to play with whislt making up a press to change them.
Or I could talk about what happens if you don't do up the gear box output flange to driveshaft bolts tight enough
Or how much pressure it takes to completely strip the thread from a final drive drain........
And those art just a few of my "clangers" ,
« Reply #8 on: April 08, 2016, 11:45:57 PM »
It's good to know I'm not the only one.  :D
« Reply #9 on: April 11, 2016, 11:50:10 AM »
I like your theory.
The only thing I liked about it was after I had the nipple installed, the cable broke at the last clutch pull to get into my mechanic's driveway to get a replacement cable. Luckily I was able to find the nipple there in the street.
