Author Topic: front wheel mystery  (Read 927 times)
Offline Oconner
  • Sunny So Cal.
front wheel mystery
« on: March 21, 2016, 03:14:38 PM »
When I have the bike on center stand and front wheel in air if wheel is straight or to the left the wheel spins like butter, once I turn it about 10-20 degrees to the right it binds at one spot and slows the wheel. It does this all the way to full lock on the right side. I checked the break rotor it appears to have no warping. Do you think its the break line. I checked and nothing is pinching or even moving when the bars are turning? It is a very slight dragging so it really doesn't effect the ride but not sure long term what it might be doing. What say ye?
'82 r65LS
'72 Honda CL 350
'13 FZ6R
Re: front wheel mystery
« Reply #1 on: March 21, 2016, 03:29:27 PM »
Check for top hat type spacers on the right caliper, where the bolts go through the fork leg .
There are different thickness flanges to get the caliper centered on the rotor .
« Reply #2 on: March 21, 2016, 06:01:29 PM »
Take your disc pads out and I'll bet it doesn't happen any more.
But if it is not a loose pad "leaning" on the disc, then the next suspect is your axle nut not be tight or a bearing in the process of failure.
thrang
« Reply #3 on: March 22, 2016, 10:50:04 AM »
I'm going to take a punt and say check your wheel bearings.
« Reply #4 on: March 22, 2016, 04:19:02 PM »
Bob, I've been putting up with this for a few years and it's had me scratching my head.  The wheel bearings are good (and I'd thing the ball bearings in the LS wheel wouldn't care as much about axle torque).  Now I wonder if swapping the top and bottom caliper tophat spacers will fix the problem (and is what caused the problem in the first place) [smiley=wall.gif]
Question is, why the heck would BMW make the left hand caliper simply bolt up to the fork and stay centered while the right side needs special shimming?
