Author Topic: Oil leak  (Read 3148 times)
Re: Oil leak
« Reply #15 on: February 18, 2016, 01:34:41 PM »
Those grommets look like the same type I got from Moto Bins a little over a year ago .l
Offline Matt Chapter
  • <insert witty remark here>
Re: Oil leak
« Reply #16 on: February 19, 2016, 08:19:56 AM »
You have the raised ridges on the grommets properly oriented.
Ah, but the trick is these grommets did not fit that way.  During installation they lined up like this: _--  Rotated 180 degrees and they fit fine.  They also protrude less than the originals.  I think the confusion stems from the chassis being an '86, i.e. an R80 with smaller cylinders, but the motor actually being an '84.  I'm monitoring the situation closely, and I've done a couple hundred miles since with no leaks.  (Gassed up Tuesday morning, 192 miles later gassed up last night.)
'04 R1150 RT ~41000 miles
