Author Topic: R65G/S future and past modifications  (Read 6106 times)
Re: R65G/S future and past modifications
« Reply #15 on: December 06, 2006, 07:49:37 PM »
That is one interesting machine you are brewing up...
Baffo
« Reply #16 on: January 31, 2007, 09:36:21 AM »
Replaced the other 7 cylinder bolt threads for helicoils today (a 2nd one was coming loose on its own and got fed up with it  8-) ) So now I can start test fitting the 'new' exhaust system, but questions arose today for the valve clearance.
I have an R80G/S book which says IN 10mm and EX 15mm, and a general BMW book says IN 10mm EX 20mm (for R45/65/LS and  R80 +1985), and I have this odd R65G/S so in a way for offroading you'd say a bit bigger clearance, for fiestier response smaller clearance, and higher revving engines bigger clearances. It's at 15/20mm now
So what do you use (with which engine) and what would you recommend, onroad inner-city and B-roads.
« Last Edit: January 31, 2007, 09:45:19 AM by Baffo »
Baffo
« Reply #17 on: February 12, 2007, 10:10:06 AM »
'New' leaky tank from ebay:
welded and painted:
Coating old tank?
« Last Edit: February 12, 2007, 10:27:51 AM by Baffo »
Joan
« Reply #18 on: February 28, 2007, 09:53:16 PM »
You are brave and strong to ride a 400+ lb dirt bike! I finally saw an R65GS up close and personal at the 2004 National BMWMOA rally in Spokane WA, got pics somewhere... made me want to make one too for backcountry fishing, but talked myself into a 300lb single dualsport instead.
I really like the front end upgrades! Very nice! Keep the progress reports coming!
Chris_in_BC
« Reply #19 on: March 01, 2007, 02:03:30 AM »
I have an R80G/S book which says IN 10mm and EX 15mm, and a general BMW book says IN 10mm EX 20mm (for R45/65/LS and  R80 +1985), and I have this odd R65G/S so in a way for offroading you'd say a bit bigger clearance, for feistier response smaller clearance, and higher revving engines bigger clearances. It's at 15/20mm now
I also have a 1999 Haynes that says the latest recommendation is 15/25mm for ALL airheads.
Personally I run 10/20mm in all bikes '78 R100RS, '81 R80G/S and '81 R65 (all three are high mileage)
You aren't going to be able to tell 'feistier response' whether it is 15 or 20 mm.
I always work on the old adage, 'Noisy valves are happy valves"
Chris
Baffo
« Reply #20 on: March 01, 2007, 05:11:20 AM »
300lbs singles, been there done that (see my website) Now just want to make this cow a little sportier, especially suspension, brakes and 17 inches. But first I'm getting 2 small city cases and have to modify the Z-bars from an R100
Exhaust valve clearances doesn't differ all that much in response, I know, inlet valves on the other hand...
Baffo
« Reply #21 on: May 20, 2007, 11:35:57 AM »
Ok where was I...  8-)
preparing Acewell 2853 digital dashboard:
4 more pics:
O yeah, bought a leaking R80G/S WP shock on ebay which turned out to be a 365mm (instead of a 359mm) had it serviced for road use (thicker oil) and now its too rigid (ugh my back) even on 1st of 11 settings, so have to go back for intermediate thickness oil, 90km/h speedbumping rules !  ;D
« Last Edit: May 20, 2007, 11:39:34 AM by Baffo »
Baffo
« Reply #22 on: May 26, 2007, 02:05:23 PM »
Jon_P
« Reply #23 on: May 26, 2007, 03:14:20 PM »
i like the rebuilt rear frame section. if i am ever lucky enough to find a 85 and up i would like to do something like that.
« Reply #24 on: May 26, 2007, 06:16:16 PM »
That is really a trick looking dash you're building...
thrang
« Reply #25 on: May 26, 2007, 06:31:06 PM »
Any chance of a wee write up on how you've gone about fitting that digital dash, components etc. Because the piccys have got me thinking along those lines as a mod for the Bimbo when I get round to putting her back together.
Baffo
« Reply #26 on: May 27, 2007, 03:21:55 AM »
The meter is an Acewell 2853, wiring specs here , rest is handmade as I went along so no specs
Jon_P
« Reply #27 on: May 27, 2007, 10:00:16 AM »
so the speed pick up is on the front wheel? did they give enough wire to run it off the back wheel? i ask because i would like to run a duel disc up front and that would make a nice set up if i could do that.
Baffo
« Reply #28 on: May 27, 2007, 05:12:00 PM »
Not sure if it would be long enough for the rear wheel but with dual brakes you can still run it up front (am getting dual brakes too), and you can extend the wire yourself easily
Baffo
« Reply #29 on: June 09, 2007, 11:05:31 AM »
