Author Topic: Rear brake binding  (Read 913 times)
Offline MichaelSydney
  • One of the Australian mob!
Rear brake binding
« on: December 10, 2015, 06:42:39 AM »
I had something strange happen today.
I went for a fast thrash up a very twisty road. I think it rises about 800 meters in 8 km. Lots of  hairpins and today the summit was above the cloud line.
Last night I did a carburetor rebuild and I was naturally worried when nearing the top the bike seems to lose power. I found a safe spot and coasted to a stop. Except I did not coast.... the bike simply stopped.... rear brake firmly engaged. I could see no obvious problems so simply backed off the adjuster three half turns then all was normal. I later wound two half turns back on before attempting the descent on anther road.
A short while back I had the wheel off and inspected shoes and drum. All seemed in order. What could have happened?
Re: Rear brake binding
« Reply #1 on: December 10, 2015, 08:34:56 AM »
Michael, you may have kicked up some debris as you were drifting the LS through those twisties. Note the five (5) open-to-atmosphere vents on the wheel's port side. Would not be outside the range of probability that a bit o' grit found its way inside and lodged between the leading edge of a brake shoe and the drum.
Just my guess but go ahead and pull the wheel for inspection. You might see a scored line on the drum surface where the odd bit was ground away which restored the usual less than sterling rear brake. Or you may find a pebble!
Just my guess and no more.
« Reply #2 on: December 11, 2015, 01:32:35 PM »
Thank you Montmil, that certainly sounds plausible. I will inspect carefully for any sign of debris in the drum.
Offline Burt
« Reply #3 on: December 11, 2015, 10:13:22 PM »
Earlier in the year a picked up a spare rear wheel for my K75C which has essentially the same set up as an R series with drum brakes.  I also picked up the FD to match it.
I noticed that on the outer rim where the wheel hub joins the diff, there was serious pitting all around the mating surface.  As there is a small gap when fitted and the lower mating surface of the FD has pitting, it could be the result of a small stone getting caught.
Black 1984 R65 - the Wombat
