Author Topic: floppy turnsignals  (Read 2941 times)
rob650
floppy turnsignals
« on: September 16, 2007, 08:47:48 PM »
hmm sounds like some kinda personal problem....
all my turnsignal pods(?) have up and down rotation play to them , some almost 2 inches of travel.  I've opened them up and can't figure how to "tighten" them back down...  Anybody else had this happen?  I'm sure the bike has been dropped a few times in its life and knocked them loose.  Thanks.
Re: floppy turnsignals
« Reply #1 on: September 16, 2007, 08:55:44 PM »
If you remove the lens, then the reflector assembly, there are 2 screws that hold down a metal clamp that secures the black plastic housing to the metal tube.
« Last Edit: September 16, 2007, 08:56:02 PM by Bob_Roller »
« Reply #2 on: September 16, 2007, 09:01:07 PM »
Also, sometimes the little sheet-metal clamp deforms so you may need to take it out and bend some "tension" back into it...
« Reply #3 on: September 16, 2007, 10:29:55 PM »
It also helps to wrap a layer or 2 of black electrical tape around the stalk where it slides into the signal body.
"Fattens" things up a bit, and you can't see it inside the blinker housing.
« Reply #4 on: September 17, 2007, 06:49:31 PM »
I have also found that not only do the silver metal pieces that have the tang on them (inside the T.S.) get deformed, but the matching groove that they slide into on the stalk diameter can get wider.
I think I like the electrical tape idea the best.
« Last Edit: September 17, 2007, 06:49:57 PM by Rob_Valdez_79_R65 »
airhead
« Reply #5 on: September 17, 2007, 06:58:58 PM »
You could apply some Zen to your motorcycle maintenance and cut a sliver of shim material from a beer can to fit in there!!!
Bill...................;-)
(with apologies to Guru Persig)
« Reply #6 on: September 17, 2007, 07:08:23 PM »
Surely, Bill, you don't advocate using a "beer-can" shim on a BMW!!??  ;)
I have found that the tape is a quick and not long-lived fix so I always try to put more "grab" into the clamping mechanism...  Now, maybe some of that stainless steel metal tape might do the trick, or a shim...  :P
thrang
« Reply #7 on: September 17, 2007, 07:31:28 PM »
A beer can shim is an integral part of any quality bodge...
« Reply #8 on: September 17, 2007, 07:55:09 PM »
It was also a "fix" that horrified a BMW owner in "Zen and the Art...", if I remember correctly.
« Reply #9 on: September 17, 2007, 08:03:27 PM »
As long as it's a Beck's or Heineken beer can it's acceptable.
« Reply #10 on: September 17, 2007, 10:45:51 PM »
Actually - Thanks for the idea!  I need to shim the levers on the Firebird.   [smiley=beerchug.gif]
Paul
« Reply #11 on: September 18, 2007, 11:19:07 AM »
Except, Heineken is from Holland.
Paul
« Reply #12 on: September 19, 2007, 08:29:57 PM »
I've got a turnsignal that always seems to start drooping on Tillie after 40-50 miles -
I usually drink beer in bottles, but since they don't make very good shims I'll have to
pick up something else on the way home this week... ::)
« Reply #13 on: September 19, 2007, 10:35:47 PM »
I've been finding Pilsner Urquel in cans lately.  Much better than in their green glass bottles, as the beer in them always tastes as though it's been exposed to light.  That's Czech beer, though, not German.  Very good pilsner, for when I don't want IPA.  In fact, the bulk of my annual home brew production and consumption is an attempt to copy P. Urquel.
airhead
« Reply #14 on: September 20, 2007, 06:36:40 AM »
But Ed, surely with a name like Miller......................................!!
Bill..................;-)
