Author Topic: Leaky Carb.  (Read 1051 times)
Ron_S.
Leaky Carb.
« on: June 16, 2015, 06:33:17 PM »
I have a 1986 R65 and one carb is leaking where the brass nozzle goes into the carb. Is it possible to buy a new nozzle? If so, how do I press it into the carb? I think it is pressed at the factory. Thanks for any help.
Re: Leaky Carb.
« Reply #1 on: June 16, 2015, 08:30:15 PM »
You might check the Bing website to see if this is an available piece but I don't believe it is.
If it's leaky but still stuck in the carb body, I'd consider trying a LockTite stud locker liquid. I used this product in securing case studs in VW engine blocks and it's resistant to heat and chemicals.Use some carb cleaner to prep the joint line. Dribble a little around the brass tube's contact joint to the carb body and let it cure per instructions.
Ron_S.
Re: Leaky Carb.
« Reply #2 on: June 16, 2015, 09:23:53 PM »
Many thanks. I'll report the results.
Re: Leaky Carb.
« Reply #3 on: June 17, 2015, 06:46:50 AM »
Have you tried giving the spigot a little tap with a hammer to see if it is seated. Getting the spigot out might do additional damage so wicking loctite might be worth a try. Dear stuff though so I'd try a little tap first.
Re: Leaky Carb.
« Reply #4 on: June 17, 2015, 07:20:57 PM »
+1
Do not pull it out if you have not already done so. Loctite if it hasn't been pulled out, Something more "adhesive" (say Devcon) if it has.
Spigots coming loose is a constant problem with VWs, in the past I have used both Loctite wick-in and the devcon solutions. The secondary advice is to keep an eye out for a serviceable carb body.
Ron_S.
Re: Leaky Carb.
« Reply #5 on: July 30, 2015, 04:14:14 PM »
After much searching I finally found in a red bottle 290 loctite wicking, green in color. Tried tapping the spigot, per suggestion. Still leaking. Got the connection as clean as I could, dribbled the loctite in there, propped the carb up level and let it set 24 hours. Eager with anticipation I tried it the next day and it leaked gas like a fiend. Seems as though the gasoline dissolved the loctite.
Time to start over. Onward and upward...or at least onward.
Ron_S.
Re: Leaky Carb.
« Reply #6 on: July 30, 2015, 04:14:52 PM »
