Author Topic: Aftermarket Tacho FYI  (Read 1007 times)
jonwill001
« on: May 20, 2015, 08:59:42 AM »
Hi. I bought for my 1980 R45 a Koso cafe racer speedo/tacho from digitalspeedos.co.uk
I have had it about 12 months now, and whilst pleased with it, have never been able to stop the tacho needle fluttering. (It ticks over between 500 and 3000 revs!)
I have looked on the internet and there seems to be many people with a similar problem on various bikes when using aftermarket tacho's. I have tried wrapping the tacho wire around the plug lead, re-routing away from other power cables, Connecting to + & - coil outputs, Fitting a large resister to the rpm lead all to no avail.
Today I solved the problem. I cut the rpm wire and fitted a small LED. (My son had bought a small light up christmas tree construction kit from maplin and had an LED left over)
Just took it for a test ride. perfect. No flutter at all. No delay. Just a perfectly working tacho
Thought i'd share this incase anyone else in the group has, or have had, a similar problem
Jon
Re: Aftermarket Tacho FYI
« Reply #1 on: May 20, 2015, 09:38:33 AM »
Now that's a real pub story! Odd that.
Offline Julio A.
« Reply #2 on: May 21, 2015, 03:35:50 AM »
Seems to me there is electrical noise somewhere in the signal that confuses the tachometer. The LED could be filtering that out.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
