Author Topic: Seeking assistance on front mudguard  (Read 1810 times)
« on: April 16, 2015, 12:07:24 PM »
I'm currently focusing on the front mudguard, it comes in two parts, the main coloured guard itself and what appears to be a metal bracket or support that fits under the mudguard itself.
Mine is badly corroded and I struggled to get it off what bending it slightly. It really is in bad shape. I checked on real OEM and no part number, it seems to come as part of the mudguard itself.
Any ideas or did somebody come up with a great fix?
Appreciate the help, thanks
Chris
Re: Seeking assistance on front mudguard
« Reply #1 on: April 16, 2015, 12:36:27 PM »
The metal part is the fork brace.  Is it so bad you couldn't get it blasted and re-plated or painted.  It is important though for minimising fork stiction  that it fits well and doesn't put any stress on the fork legs.
I see motobins sell them separately and nice stainless steel ones at that  but only for type 247 airheads. You can get a bit fed up continually reading (not R45/65).
« Last Edit: April 16, 2015, 12:42:53 PM by bhodgson »
« Reply #2 on: April 16, 2015, 01:18:37 PM »
I found this on RealOEM .
http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=31_0297&hg=31&fg=42
Item # 5, now if it's still availalbe !!!!
« Last Edit: April 16, 2015, 01:19:48 PM by Bob_Roller »
« Reply #3 on: April 16, 2015, 02:01:20 PM »
Max BMW shows it as available at $80
« Reply #4 on: April 16, 2015, 02:10:49 PM »
Just checked with the local dealer parts guy (very helpful). There are none here in the colonies but he said they are showing stock of 96 pieces in Germany, so it is still available to order.
« Reply #5 on: April 16, 2015, 03:35:34 PM »
They do come up occasionally on eBay usually around $30. I am stunned that BMW still has 96 of them - for a part  that ceased to be used that is amazing.
Now if only they still had ignition switches, headlamps and accessory pods.
« Reply #6 on: April 16, 2015, 04:59:42 PM »
Thanks to all for fast response as always!!!!!
Chris
