Author Topic: Head Repair  (Read 3838 times)
Offline D Mann
Head Repair
« on: April 08, 2014, 12:06:43 PM »
Just finished replacing the timing chain and went to adjust the valves. Left side no problem, right side no clearance even with adjusters backed all of the way off. Yes I rotated the engine 360 deg and watched the valves close. I need some recommendations for a shop that can do a good job on the heads without breaking the bank. I am in northern Illinois.
David Mann
1981 R65
ABC #14407
Offline Matt Chapter
  • <insert witty remark here>
Re: Head Repair
« Reply #1 on: April 08, 2014, 12:56:12 PM »
Common suggestion, although I'm not familiar with your neck of the woods: air cooled VW mechanics.
When I had my head worked for a broken exhaust valve, worn guide resulting from same, etc, I went through my "un-affiliated" air head mechanic.  He's a bit of a unique guy, but has the knowledge and connections to get the job done.  There may be a similar individual around, especially in the Chicago area.
If you want to investigate shipping to the ATX area, check out http://www.ororcycle.com
'04 R1150 RT ~41000 miles
Re: Head Repair
« Reply #2 on: April 08, 2014, 04:45:36 PM »
Two of the very best Airhead head repair and overhaul:
West coast: Ted Porter's Beemer Shop   http://www.beemershop.com/
East coast: Tom Cutter's Rubber Chicken Racing Garage http://www.rubberchickenracinggarage.com/
Neither are "economy" shops and both gents are usually booked 5-7 months ahead for head work; particularly now that Spring has done Sprung. Prices hover near $600-700/pair for total refreshing and all new parts.
An alternative is to check eBay. Sometime years back, I purchased a pair of prefect late model R65 heads off a bike that had massive front end damage and was being parted out. Even the exhaust stub threads are virgin-like. $130.00 the pair.
Re: Head Repair
« Reply #3 on: April 08, 2014, 08:44:05 PM »
In this case it would seem to be valve seat recession, there is no cheap fix as the head needs to be welded up and then cut so a new seat can be pressed in, then the guides need to be done, new valves (probably get away with exhausts only) cut (minimum 3 angle) and grind.
If you are bucks down, a serviceable set of 2nd hand heads is an option but measure the guide clearance (a set of k-lines can be fitted cheaply and will last almost as long as new guides) and then monitor them closely. Any heads manufacturer pre-1985 may suffer from seat recession when used with unleaded or low lead fuels - there seems to be no rhyme or reason, some will recede and some will not. I dose my fuel with a lead replacement - costs me about $2.20 per tank of fuel, I regard it as insurance and as a hedge putting off the evil date I have to fit hardened seats to the exhaust valves.
Offline D Mann
Re: Head Repair
« Reply #4 on: April 09, 2014, 08:13:26 AM »
Thanks for the tips I will do some checking.
David Mann
1981 R65
ABC #14407
Offline D Mann
Re: Head Repair
« Reply #5 on: April 09, 2014, 09:59:48 AM »
Well I called a few places and Brunos in Canada looked like the quickest turn around at about 7 weeks. I pulled the exhaust and rotated the engine to see the valve through the exhaust port and suddenly there was a lot of valve clearance. I made a newbie mistake!!!! I had been watching the cam sprocket to rotate 360 deg instead of the crank sprocket. I never had my left cylinder at TDC on compression. Well I re torqued everything and there is plenty of adjustment. Sure glad I caught my mistake before I spent big money.
David Mann
1981 R65
ABC #14407
Re: Head Repair
« Reply #6 on: April 09, 2014, 02:32:29 PM »
2:1 ratio on crank and cam rotation. Swell. Now he tells me! ;D
Good you caught this now. Otherwise, you'd be buying new big n' little o-rings, a pricey head gasket and a pair of pushrod tube seals. Plus, if you don't have one, a torque wrench... which you should buy anyway.
Re: Head Repair
« Reply #7 on: April 09, 2014, 10:38:35 PM »
You do know there are marks on the flywheel for this? There's a black rubber plug behind the left carburetor covering a 'window' to view the flywheel. There's a tab on the flywheel with OT marked on it - translation = Top Dead Center.
Offline D Mann
Re: Head Repair
« Reply #8 on: April 10, 2014, 12:12:23 AM »
Yea I know, I just got caught up in cranking it around and watching the easy to see mark on the cam chain, lets face it, I had a brain fart but recovered before any damage was done.
David Mann
1981 R65
ABC #14407
RWKuechen
Re: Head Repair
« Reply #9 on: October 31, 2014, 09:16:36 PM »
I just had a set of 1979 R-65 heads re-done (and updated). Contact Leo Goff at Memphis Motor Werks.  Not cheap but I had the exhaust stubs re-done and the heads rebuilt and they came back in about 6 weeks looking like some kind of Mechanical Pornography.  The bike is finished and it runs like a champ.  Excellent Value for Money. Highly Recommend. :) Very Professional.
Re: Head Repair
« Reply #10 on: November 03, 2014, 08:51:51 PM »
Dang, I always put my thumb in the sparkplug hole and when I feel compression I poke a drinking straw through and use it as a TDC indicator as I "bump" it...
Offline decorn33
  • Loving my R65
Re: Head Repair
« Reply #11 on: November 05, 2014, 04:03:45 PM »
Hurray! I'm not the only one to use the thumb over the sparkplug hole - feel for compression - check for TDC with a straw approach. I even have a dedicated straw.
1984 R65
Re: Head Repair
« Reply #12 on: November 05, 2014, 04:50:50 PM »
I still have one of these ancient things (micro-time) dating from the time when setting timing was a black art.
books.google.com.au/books?id=SNgDAAAAMBAJ
Re: Head Repair
« Reply #13 on: November 07, 2014, 04:14:19 PM »
Tony, I too have a vintage Micro-Time tool. Still have the booklet that came with it -giving what mark on the plunger should be 'locked in' for timing a Yamaha DT-1, etc. Been in my tool chest for over 40 years.
Re: Head Repair
« Reply #14 on: November 10, 2014, 01:34:41 AM »
Mine was purchased to use on a Bultaco Sherpa-T, 1975 seems a long, long way away now.....
but i think you are a few years older than me.
