Author Topic: 4.00-18 VS 120/90 -18 Metzeller  (Read 1045 times)
« on: September 28, 2014, 07:33:13 PM »
Hello all
I am getting a new tire for the back of my R65
Is switching from a  120/90 to a 4.00  going lower my overall gearing.
   I need to get as much speed out of  4200rpm  that I can get .
I could not find any specs on outside Dia on the Metzeler site
If someone has a 400-18 mounted  could you measure the outside dia or the radius for me  (from ground to center of rear axle)
Thanks for the help :)
« Last Edit: September 28, 2014, 09:51:29 PM by Mrclubike »
Re: 4.00-18 VS 120/90 -18 Metzeller
« Reply #1 on: September 28, 2014, 10:29:02 PM »
I did find a size chart on Avon tires and it less than 1% difference in a 400 and a 120/90
not enough to worry about  ::)
« Reply #2 on: October 02, 2014, 05:19:12 AM »
Here is something I put together a while back for different tires.  Let me know if you have some new info and I'll add it.
« Reply #3 on: October 02, 2014, 10:11:28 PM »
        wide    tall
Avon Roadrider AM26 (rear)      4.00-18       116        671
Avon  Roadrider AM26 (rear)      120/90-18       129    675
« Last Edit: October 02, 2014, 10:13:10 PM by Mrclubike »
« Reply #4 on: October 03, 2014, 03:08:57 AM »
Thanks
I'll update the table
