Author Topic: Loose exhaust coupling  (Read 2048 times)
Offline jamestnewsonr65
« on: August 17, 2014, 01:17:02 PM »
I bought some mufflers from here http://modernmotorcycle.co/collections/exhaust/products/muffler-reverse-cone-megaphone-shorty-black and they came with some reducer collars which I thought, great just put them on, clamp the, up and good to go. Wrong!
Even with the reducers which are supposed to take you down to 35mm they are a little loose and don't sit properly. Does anyone have and ideas on how to make them tighter fitting or indeed where to get a smaller fitting collar?
Thanks in advance.
James.
1981 R65 (box of bits).
Re: Loose exhaust coupling
« Reply #1 on: August 17, 2014, 06:25:03 PM »
« Reply #2 on: August 18, 2014, 03:32:21 AM »
It was more the internal reducers.
They just don't seem to squeeze together enough to hold the muffler tight.
« Last Edit: August 18, 2014, 03:34:22 AM by jamestnewsonr65 »
« Reply #3 on: August 19, 2014, 03:53:57 PM »
Cut some strips from brass shim stock. Roll 'em up inside those reducers. Should get you snugged up.
« Reply #4 on: August 19, 2014, 05:06:02 PM »
I thought that might've an option or cutting the reducers a bit so they close up a little tighter.
Shims are probably easier!
« Reply #5 on: August 20, 2014, 09:03:03 AM »
Monte, brass shim stock?  This would be a great opportunity to re-use some spent beer cans!  [smiley=beer.gif]
youngjohn
« Reply #6 on: August 20, 2014, 12:27:53 PM »
Try greasing between the reducing rings so that they slide over each other more easily. I had one of these a few years ago and that did the trick for me.
« Reply #7 on: August 20, 2014, 03:15:06 PM »
Done that!
Plus, a 12-ouncer makes a great install tool for a final drive oil seal. Beer... It's not just what's for breakfast.
