Author Topic: Braided Brake Lines - 2 instead of 3?  (Read 3514 times)
youngjohn
« on: July 18, 2014, 07:19:43 PM »
Has anyone swapped the one into two standard brake lines for two separate lines coming straight from the master cylinder to the individual callipers (on twin calliper bikes)?
If so, do you have a brand or part number?
Thanks.
Offline jamestnewsonr65
Re: Braided Brake Lines - 2 instead of 3?
« Reply #1 on: July 20, 2014, 01:42:35 AM »
Steve has done this and took some pics for me of his bike. http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1403614072
He said he got his from here: http://goodridge.brakes-hoses-fittings.co.uk.
I am going to do the same with my install as I build the bike back up.
1981 R65 (box of bits).
« Reply #2 on: July 21, 2014, 11:44:55 AM »
Just curious, is there a functional reason for doing this or is it strictly aesthetics.
« Reply #3 on: July 21, 2014, 04:43:41 PM »
For me it is completely aesthetic as I want a clean front end.
balibeemer
« Reply #4 on: July 21, 2014, 08:09:44 PM »
Interesting - i guess that it balances the pistons on both sides?
« Reply #5 on: July 22, 2014, 08:29:39 AM »
Stock setup is balanced.  This setup would just be like moving the stock splitter all the way up to the master cylinder.
« Reply #6 on: July 22, 2014, 08:48:34 AM »
There is a lot of extra 'bracketry' and pipes on the original BMW setup, even more so with the R100.
It won't work any better, but it will remove any extraneous clutter.  BMW could always be relied upon to make a system more complicated than strictly necessary.
« Reply #7 on: July 22, 2014, 05:17:34 PM »
OTOH When did you last hear of BMW brake lines chafing?
« Reply #8 on: July 22, 2014, 08:27:28 PM »
and, erm, splitters are found on every dual disc bike and multi-brake car I can think of.  Plus, if you're going to use a hydraulic brake light switch, as some of our bikes did, you need somewhere to put it.
The short steel lines down at the calipers are different than most motorcycles... but I guess there's some flawless engineering behind that... less stress at the crimped hose ends or something  ;)
« Last Edit: July 22, 2014, 08:29:37 PM by Luca »
youngjohn
« Reply #9 on: July 25, 2014, 08:43:30 AM »
Thanks for all the help - i've ordered a pair.
