Author Topic: Steering Damper Measurements?  (Read 3557 times)
Offline R65Singh
Re: Steering Damper Measurements?
« Reply #15 on: July 15, 2014, 09:43:09 PM »
Here are some picture of the factory set up of steering damper as requested by a member.  It basically attaches to the same bracket where the horn is attached.  The other side attaches to the triple tee's bottom side, there is already a threaded tap in there.
« Last Edit: July 15, 2014, 09:47:16 PM by koolzee »
1982 R65LS
1970 r50/5
1962 r50/2
1976 Honda Z50
Offline ShutterPilot
« Reply #16 on: July 16, 2014, 07:58:29 AM »
Thanks for the pics Singh! Very helpful.
I'm assuming the 1st photo is the bracket with damper removed, showing the mount hole at center.
As soon as I get my R65 back, I'll check to see if the mount is similar.
Also, I've lightened your photos just a bit, to perhaps show the damper placement better.
« Last Edit: July 16, 2014, 08:04:54 AM by ShutterPilot »
Offline DanMay
« Reply #17 on: July 22, 2014, 07:33:47 PM »
I think I posted this before, but here it is again.  I am running a damper on my 1982 R65LS.
The damper that fits the R65 is the NHK ODM500:
http://www.fastfromthepast.com/servlet/the-1004/Steering-Damper-Stroke%3D85mm-/Detail
I ordered these OEM BMW parts for mounting:
31 42 1 237 285
07 11 9 931 684
07 11 9 932 850
07 11 9 931 019
07 12 9 906 196
See pics for details.
