Author Topic: Swing arm bearing installation  (Read 1861 times)
Offline jamestnewsonr65
« on: June 25, 2014, 09:02:20 AM »
Hi there, as you might be able to see I have been asking a few questions lately. I seem to be at the point where I have run out of knowledge and need some help to progress, apologies for the barrage of questions.
I need to install new bearings along with seals and grease baffle into the swingarm and cant seem to find a definitive example of how these go in. I have also seen reference to a spacer for the swingarm, but the diagram on realoem doesn't really define what all the parts are.
I have done a search on here but can't seem to find anything relating to the swing arm.
Any help is greatly appreciated.
Thanks
James
1981 R65 (box of bits).
Re: Swing arm bearing installation
« Reply #1 on: June 25, 2014, 12:30:08 PM »
I don't know about a spacer.  It's not like a wheel bearing in that respect as the swinging arm tube itself is the spacer.
In principle it's simple: grease baffle first then the bearing followed possibly by a thrust washer or seal.  The type of bearing changed to a seal bearing at some point so there may be no separate seal or thrust washer.  The bearing pin then locates into the inner race and pre-load is provided by torquing the pin to 15 ftlb to seat the bearings then backing off and re-torquing to 7.5 ftlbs to provide some running pre-load.  Expect some adjustment to get swinging arm centred and the gaps equal.
« Last Edit: June 25, 2014, 12:31:27 PM by bhodgson »
« Reply #2 on: June 25, 2014, 05:20:00 PM »
Brilliant, thanks Barry.
As I'm away from the bike this week, I am trying to gain all the knowledge I need to start the next phase of resto.
Thanks again.
James.
lukasgrech
« Reply #3 on: July 02, 2014, 01:10:00 PM »
Related, possibly stupid question:
What grease does one generally use on swing arm bearings? I've just re-installed my swing arm and set the pivot pins and lock nuts, the only thing left is the grease. Does regular all-purpose grease cut it, or is moly grease used?
Thanks
arvo92
« Reply #4 on: July 02, 2014, 01:26:30 PM »
As far as my knowledge goes - you want Lithium based grease on your bearings. Moly grease on your splines. Molybdenum based greases turn to flakes when they get the handling ball bearings provide them with mixing the grease into whipped cream/grease.
I use pretty regular LM grease provided by Castrol.
« Reply #5 on: July 02, 2014, 02:28:02 PM »
Regular all purpose grease that you might use on wheel bearings will be fine.
To grease the bearings in future you will need a conical tip for your grease gun which will enable you to force grease through the centre hole of the bearing pins.
« Reply #6 on: July 02, 2014, 08:09:19 PM »
I understand that there's not likely to be a Tractor Supply store in the UK, but this agricultural-based business franchise does sell a nice conical, rubber tip for a grease gun that does an excellent job on greasing the swingarm bearings.
lukasgrech
« Reply #7 on: July 03, 2014, 02:05:56 AM »
Lovely, thanks!
Was already in possession of a conical tip for grease gun :D
bjamesw
« Reply #8 on: July 05, 2014, 02:47:50 AM »
I had to lathe a millimeter off of the craftsman socket to install/torque the swingarm nut.   Anybody else?
« Reply #9 on: July 05, 2014, 04:34:32 AM »
Yes and also off the end of the socket to remove the lead in so that the socket gets maximum purchase on the slim locknut.
« Last Edit: July 05, 2014, 04:35:03 AM by bhodgson »
« Reply #10 on: July 05, 2014, 08:28:18 AM »
Depends on the brand of socket you have. I found a socket that fit at Lowe's without requiring any mods other than dressing off the end on a belt sander. Shop wisely, grasshopper.
Those modified sockets sold by BMW tool sellers ain't particularly cheap, either.
« Last Edit: July 05, 2014, 08:29:22 AM by montmil »
