Author Topic: Feeble brake light  (Read 1683 times)
Feeble brake light
« on: June 22, 2014, 11:52:51 AM »
I was riding with my brother yesterday, he has a '76 R90. We switched bikes for a while, and while riding behind him I noticed how weak my brake light is. I'll open and up and see if anything can be done to mprove the existing fixture, but I suspect it is what it is.
I'm thinking about adding something like this, anyone have anything to suggest?
http://www.cyclegear.com/CycleGear/Parts/Electrical/LED-Accent-Lights/brand/GYB-PRODUCTS/Stopper-Brake-Plate-LED-Light/p/33981_59435
Re: Feeble brake light
« Reply #1 on: June 22, 2014, 02:14:45 PM »
For $60 you can get the Beacon 2 tail light from Rick Jones at Motorrad Electric (motoelekt.com).  I've got one on my bike.  Super bright, draws less power than stock, and fits in place of the stock tail lamp reflector.  I'd buy another without thinking twice about it.
« Reply #2 on: June 22, 2014, 04:16:44 PM »
That looks like a great solution, I'll give them a call tomorrow. Thanks!
Offline wilcom
« Reply #3 on: June 22, 2014, 08:11:35 PM »
I run "hyper lites" running and brake, it's another option to look at
http://www.hyperlites.com/
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #4 on: June 23, 2014, 09:49:39 AM »
+1 another vote for the Beacon-2 tailight assembly - quick easy and reliably bright.  Also, won't run the risk of melting through your red plastic lense cover as some people do when they fit an incorrect (larger size and wattage) incandescent bulb.
« Reply #5 on: June 23, 2014, 10:08:34 AM »
I am using Hyperlites on my K75s. There is an unused area, left and right, inside the brake light housing on K bikes. The Hyperlites install inside the tail light lens and are very effective.
« Reply #6 on: June 23, 2014, 12:11:09 PM »
I have the Beacon 2, the Stopper LED light strip on the bottom of my license plate, and a generic version of Hyperlights, Electropods .
I do a lot of night riding and all of these items have proven useful to me .
If someone is following too closely, I put the rear brake on lightly, the light switch turns on long before the shoes start to make contact on the drum .
Most of the time the tailgater, backs off .
Offline davidpdx
« Reply #7 on: June 23, 2014, 04:15:05 PM »
These folks will sell you a nice setup that makes your brake lights flash when you first put the on. superbrightleds.com
1       1156-x19: 1156 LED Bulb - Single Intensity 19 LED 1156-R19-WV: 1156 Red 100 Degree       $6.99
1       1156-x24: 1156 LED Bulb - Single Intensity 24 LED 1156-R24-WV: 1156 Red 100 Degree       $7.49
1       LSC-100A: Brake Light Strobe Module LSC-100A: Brake Light Strobe Module       $4.95
It requires a little wiring but is cheap and has lasted well so far. Not sure if it is legal in all state but it is in Oregon.
1984 R65 60K+
1946 Triumph Speed Twin
? Hunter S. Thomps
