Author Topic: 79 R65 Oil Pressure Switch Torque  (Read 1603 times)
Crossrodes
« on: May 05, 2014, 04:03:09 PM »
I'm just installing a new oil pressure switch.  Does anyone know what it should be torqued to when tightening?
Re: 79 R65 Oil Pressure Switch Torque
« Reply #1 on: May 05, 2014, 07:08:41 PM »
Torque specification for the oil pressure sender switch is "gently snugged". Don't go all gorilla torque or something will strip. That something is $$$. ;)
Really. It'll be fine.
« Reply #2 on: May 05, 2014, 07:32:18 PM »
Just like a spark plug these sorts of switches are.  But if you really want to use a number, "gently snugged" is probably around 11ftlbs on oiled threads.  You can always add a little more torque if it leaks.
Crossrodes
« Reply #3 on: May 05, 2014, 10:18:36 PM »
Thanks guys.
