Author Topic: Front Brembo Caliper question  (Read 2822 times)
tc80211
« on: May 02, 2014, 07:44:43 AM »
So I actually just need the rubber part in this picture it complete my brake rebuild. Any thoughts on a source? I see in the Fiche "Cup for ATE", is this that same cup? I know some parts are interchangeable between these Brembos and the ATEs.
Re: Front Brembo Caliper question
« Reply #1 on: May 02, 2014, 08:52:17 AM »
No idea if the ATE parts would fit the Brembo... but for good prices on Brembo bits, try these two outfits:
http://shop.bevelheaven.com/default.aspx Ducati outfit
http://www.mgcycle.com/product_info.php?products_id=591&osCsid=b0b92b623eb248e0e2114be092c8a4e9 Guzzi guys.
Your Airhead won't know the diff.
« Last Edit: May 02, 2014, 08:52:47 AM by montmil »
« Reply #2 on: May 02, 2014, 09:07:07 AM »
No the Ate and Brembo dust covers are different but to check for more info look at an excellent post done by Julio comparing the Ate and Brembo calipers.
http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1311933847
« Last Edit: May 02, 2014, 09:18:03 AM by bhodgson »
tc80211
« Reply #3 on: May 02, 2014, 09:21:40 AM »
Thanks guys!
tc80211
« Reply #4 on: May 02, 2014, 01:25:40 PM »
So our R65's have the Brembo F08 with 38mm piston?
« Reply #5 on: May 02, 2014, 02:15:31 PM »
36mm on R45/R65's
Other airheads that use dual piston calipers were 38mm
In both cases up to 1985
tc80211
« Reply #6 on: May 03, 2014, 09:17:08 PM »
ok 36mm... any recommendations on where to find the dust covers? I checked on the 2 websites above and they only carry 32mm and 38mm rebuild kits.
« Reply #7 on: May 04, 2014, 07:46:00 AM »
Motobins have an overhaul kit but I notice they are  currently out of stock
« Last Edit: May 04, 2014, 07:47:50 AM by bhodgson »
tc80211
« Reply #8 on: May 05, 2014, 09:55:09 AM »
found a rebuild kit for the 36mm via MaxBMW... $41 bucks a small rice to pay to actually have my bike stop.
« Reply #9 on: May 05, 2014, 12:53:18 PM »
Cheaper than a new pair of boots.
Dragging feet is what I see lottsa H-D riders doing as they pull up to a traffic light. ::)
