Author Topic: What Is This?  (Read 1941 times)
What Is This?
« on: September 08, 2013, 10:51:41 AM »
Can anybody tell me what this is please?
Re: What Is This?
« Reply #1 on: September 08, 2013, 11:51:16 AM »
If I'm not mistaken, that's your BMW's right-hand switch assembly, brake lever perch and throttle twist grip. ::)
If you're inquiring about what appears to be a plastic/nylon plug pushed into the perch body, that's where your missing Throttle Locking Bolt and Spring should reside. Very handy for balancing carbs and as a simple cruise control.
BMW Part # 32 72 1230874
Maybe be a bit more specific with your questions. Like, "WTF is that round plastic PoS?" That'll help us out.
Re: What Is This?
« Reply #2 on: September 08, 2013, 11:59:29 AM »
Thanks Monte,
I should have thought the question through a little better...
Thanks for the answer & part number.
Re: What Is This?
« Reply #3 on: September 08, 2013, 12:33:25 PM »
UK bikes or at least mine didn't come with the throttle locking screw as standard equipment. I have the exact same nylon plug.
Re: What Is This?
« Reply #4 on: September 08, 2013, 12:34:47 PM »
And you can spot where the PO had drilled out the mirror's threads and used a washer/bolt on the bottom side.
Pitiful what some peeps do on the cheap. :(
Re: What Is This?
« Reply #5 on: September 08, 2013, 01:06:17 PM »
Thanks Guys,
I'm still learning...
Re: What Is This?
« Reply #6 on: September 08, 2013, 01:32:08 PM »
The locking screw is really helpful for holding a steady engine rpm while completing the throttle cable balance during a full carb synch... using your DIY manometer, of course.
Barry, might this be a particular legal or safety issue in some countries?
Offline Kookaburra
Re: What Is This?
« Reply #7 on: April 26, 2014, 09:45:49 PM »
Montmil and Barry,
So to be clear, I could take out the plastic insert in my 1985 R65 and screw in a throttle stop without any other modification needed?
If true that would be awesome. I had one on my previous airhead, a 75/6 and it was so useful for warmup and and tuning.
Re: What Is This?
« Reply #8 on: April 26, 2014, 10:10:04 PM »
Correct. Note that the required spring is also included under this BMW part number.
