Author Topic: R65 no spark  (Read 3117 times)
Re: R65 no spark
« Reply #15 on: April 03, 2014, 07:27:07 PM »
Sticking my neck out; If there is a single spark when the ignition is switched off I'll rule out the switches, coil and wiring. I'd be disconnecting the battery and removing the front cover. Water inside the bean can is my WAG preventing a pulse to the coil that triggers the field collapse in the coil that produces, well you know.
crandall
Re: R65 no spark
« Reply #16 on: April 10, 2014, 03:19:50 PM »
Hi All,
Well I've given it plenty of time to dry out now with the tank off and still no spark. I've stripped the ignition switch and cleaned out all the shite that was inside, but sadly still no spark. So next thing I'll do is take a look at this bean can I've heard so much about. I remember seeing a paragraph or two in the Haynes manual about testing it. I'll keep you posted.
BTW I have posted a picture of the old girl that I took last week in happier time before I washed it.
Re: R65 no spark
« Reply #17 on: April 10, 2014, 06:45:57 PM »
Great pic, but I can see why you washed it!   :)
Offline Mike V
  • 78 R100/7 , 81 R65
Re: R65 no spark
« Reply #18 on: April 11, 2014, 01:34:21 AM »
This one is driving me crazy.
Crandall, have you checked to make sure the plug wires at the coil are pushed all the way into the coils and seated correctly?  And that your connection to the plug cap is good? How about the resistance of each plug wire, tip to tip with an Ohm Meter?
Just thought I would ask the ridiculous and obvious question before you tear into the bean can.
« Last Edit: April 11, 2014, 01:35:31 AM by Mike_V »
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
crandall
Re: R65 no spark
« Reply #19 on: April 11, 2014, 02:19:10 AM »
Hi Mike,
Yep, it's doing my head in too. I am assuming the plug leads and cap are ok as it sparks each time the ignition is switched on and off.
« Last Edit: April 11, 2014, 02:25:13 AM by crandall »
Re: R65 no spark
« Reply #20 on: April 11, 2014, 03:16:24 PM »
Here's a link to a BMW technical site .
http://bmwmotorcycletech.info/Ignition.htm
Goes through the steps to troubleshoot the sensor in the ignition canister .
« Last Edit: April 11, 2014, 03:18:55 PM by Bob_Roller »
crandall
Re: R65 no spark
« Reply #21 on: April 14, 2014, 10:08:21 AM »
Ok all, I have found the problem. When I took the front engine cover off to take a look at the bean can, I discovered that that I had squashed the wire to the bean can. The sharp edge had cut it clean in half, I soldered the wires back together and it's now running. Thank you so much for all your help on this.
Best wishes
Clint
Re: R65 no spark
« Reply #22 on: April 14, 2014, 01:42:27 PM »
Best wishes
Clint
 ;D  ;D  I did that once myownself. Was leaned over in a twisty narrow road when the engine done flat quit. A bit exciting. Called home for the truck and beer as I was 20+ miles from Nowhere, Texas. When I pulled the front cover...
