Author Topic: Instrument cowl... any creative fixes?  (Read 2811 times)
Re: Instrument cowl... any creative fixes?
« Reply #15 on: March 28, 2014, 04:31:28 PM »
I think you made a good call with the rubber backing.  Those instruments covers have some flex and take a bit of beating from vibration.  Seems like a fine line to walk; you don't want the bond to break, but if it's overly strong you might see new fractures at the edges of your backing material.
Al, if you hackerspace (or whatever they call the place where you did your powdercoating) has a big 3D printer, it would be way-cool to see a fresh cover made from scratch  8-)
P.S.  If you can find a chemical that will melt the plastic, you might be able to carefully use it to feather the edges on the outside of the cover and hide the joints
« Last Edit: March 28, 2014, 04:37:53 PM by Luca »
« Reply #16 on: March 28, 2014, 05:03:08 PM »
That would indeed be a cool project. I'd need a 3D drawing to work from, suppose BMW would donate that?  :D
« Reply #17 on: March 29, 2014, 11:25:15 AM »
Nah, you just need a 3D scanner and a decent cover
« Reply #18 on: March 29, 2014, 01:26:25 PM »
No need of a 3D printer. BMW still sell the cowl... at a little above 300 € apiece, it is a real bargain .....
livingdeadhead
« Reply #19 on: March 29, 2014, 01:43:30 PM »
i see in your point in using rubber , ive heard of gorilla glue apparently its very good , they do several types dont they?
« Reply #20 on: March 31, 2014, 02:52:23 AM »
That instrument cover is for the larger airheads and possibly the later Mono's.  It is the same as fitted to my 1982 R100 - an entirely different instrument set.
Rev Light
