Author Topic: clunking on the left cylinder  (Read 3118 times)
MR.E
« on: July 28, 2013, 02:45:05 PM »
Hello
Due to buying a few too many bikes last year i had to decide to thin out the flock, and unfortunately my red r65 went.
The fella that bought it rode it from mine to somewhere south of London, he did about 350 miles in a day on it, it ran fine loads of power and was charging perfectly.
However the exhaust had become slightly loose so the day after he took it to a BMW dealer who were quite excited by it so they slapped it on a ramp and balanced the carbs tweaking the idle mixture.
He's ridden it for about 3 days after (only about 100 miles a day) and it's not well.
it's lost all power, at about 3500 revs he has to change up or it bogs down, and now it's developed a hell of a knocking noise on the left cylinder, i've only heard it over the phone but it's loud and has cut out on him a few times.
My first thought was valve slap, any thoughts??
Thanks
Re: clunking on the left cylinder
« Reply #1 on: July 28, 2013, 04:33:39 PM »
First, confirm valve lash is to specification.
Offline Matt Chapter
  • <insert witty remark here>
« Reply #2 on: July 29, 2013, 12:27:49 PM »
You forgot step 1a.  Apply cold beer.
I'd go back to the dealer and tell them to try again.  Maybe even on level ground.  Once the carbs are out of whack, you're going to hear lots of strange sounds.  It's the classic troubleshooting technique: "My <widget> is <verbing>."  "Well, was what the last thing you did to it?"
'04 R1150 RT ~41000 miles
MR.E
« Reply #3 on: July 31, 2013, 05:25:17 AM »
think he's gone back to the dealers with a few choice words!!!
I've said i'll go down in a week to strip the rocker cover off and maybe the head if needed.
I reckon it's gonna be a valve issue
Thanks
MR.E
« Reply #4 on: September 12, 2013, 02:28:17 PM »
Turns out it had lost all but 500mm of oil and it threw a conrod bearing!!
« Reply #5 on: September 12, 2013, 03:13:43 PM »
How on earth could it have gone through all that oil and not been noticed?!? :(
« Reply #6 on: September 12, 2013, 03:20:20 PM »
Did they replace an oil filter at the dealer / shop ????????
« Reply #7 on: September 13, 2013, 08:07:06 AM »
Does /did the low oil pressure light ever come on ???
With that little bit of oil, it should have been on for some time .
MR.E
« Reply #8 on: October 03, 2013, 10:43:46 AM »
now then
been busy for a while!!
They've cut all the electrics off the bike so no warnings!!
I've got the engine on the bench to rebuild for him now!!
Hope alls well
Offline k_enn
« Reply #9 on: October 06, 2013, 01:08:42 PM »
Can you  say $2,000 o-ring???????
k_enn
original owner of:
?1982 R65
? 2014 K1300S
« Reply #10 on: October 06, 2013, 05:12:44 PM »
if that was the cause it would certainly make the 2k o-ring a bit more "real"
Has a filter cover gasket magically appeared since you sold the bike?
MR.E
« Reply #11 on: October 08, 2013, 07:46:27 AM »
Not too sure whats gone on with it, gaskets are present.
Don't know if they've done an oil change on it at the garage and forgot to fill it properly, it doesn't seem too bad though
« Reply #12 on: October 08, 2013, 08:16:41 AM »
Out of curiosity, does anybody know how much oil would be in the sump if you checked the dipstick with it screwed in?
« Reply #13 on: October 08, 2013, 09:13:15 AM »
No but it wouldn't be hard to estimate by comparing the length of thread with the min and max marks. Oil volume between min and max marks is 0.85 L
MR.E
« Reply #14 on: March 22, 2014, 05:08:00 PM »
Dragging up an old thread.
i stripped the engine, after he'd had it at a bmw dealer for the carbs balanced and a check over.
It has no oil in it, and a ruined crankshaft, it's really cooked it!
I lent him my spare engine to put him on, but with the repair this needs i might as well work on this and put a new crank in.
Elliott
