Author Topic: Gearbox Seals  (Read 1121 times)
Offline Adrian
  • The Old Hairy Biker Sez...
Gearbox Seals
« on: February 28, 2014, 03:25:45 AM »
Hi there. While I have my gearbox in the kitchen - yes I'm single - I would like to replace the 3 seals. Is this possible without dismantling the box? Can I remove them fairly easily and then - using a suitable sized drift - drift the new ones into place?
 I have tried Snowbum's site for info but haven't been able to find any information. My workshop manual is packed away at the moment. Thanks ....... Adrian
1984 R65 (860)
Re: Gearbox Seals
« Reply #1 on: February 28, 2014, 04:17:19 AM »
At the age of 16 when I was still living at home I once smuggled a car engine up the stairs stripped it for overhaul on the bedroom floor and hid it under my bed. OK it was only a 500cc twin cylinder air cooled  But I still got earful when my mum found it.
I've never done it but I believe you can change all the seals from the outside of the box. Gear change seal is easy enough. Input seal should be OK but the output seal is going to be a bear as you have to remove the drive flange. Is it actually  leaking ?
« Last Edit: February 28, 2014, 04:22:23 AM by bhodgson »
raypond
Re: Gearbox Seals
« Reply #2 on: February 28, 2014, 08:07:29 PM »
G'day Adrian,
Yeah, I'm with Barry. All three can be done from outside but the output one requires the flange to be removed. You won't be able to hold the box solid enough to do that on your kitchen table. You also really need a special puller and a breaker bar about 6 foot long.
Ray
Offline Adrian
Re: Gearbox Seals
« Reply #3 on: February 28, 2014, 10:29:31 PM »
Okay thanks guys - I might give it to my local workshop then - the seals aren't leaking but they have been in the box since 1984 so when I put it all back together in the future I want to be sure that nothing will leak  ;)
1984 R65 (860)
raypond
Re: Gearbox Seals
« Reply #4 on: February 28, 2014, 11:10:27 PM »
I'm in Beechworth in NE Vic and have the tools if you want to borrow them.
Ray
Offline Adrian
Re: Gearbox Seals
« Reply #5 on: March 01, 2014, 02:35:43 AM »
Okay thanks for the offer Ray that's very kind of you. I'll let you know .....
1984 R65 (860)
Re: Gearbox Seals
« Reply #6 on: March 01, 2014, 09:19:36 AM »
Ray
Now THAT's the Airhead way! Good on ya, Ray.
