Author Topic: Power cutting out when wheel is turned ??  (Read 1438 times)
apaiva
« on: October 23, 2013, 11:51:41 AM »
hey so my R65 did a curious thing yesterday.  It did this a few times last night as I rode around and took me a few minutes to figure out when it was happening but it seems like the power would cut off at times when the wheel was turned in a certain way.  It would happen when I was either idling in neutral at a stop, and also happened as I was slowing down to stop but still in gear.  It never happened when I was really moving, only either at a stop or coming to a stop.  As you can see in the video, all the power seems to cut off when the wheel is turned from the left to the right.  In the video it happens before I turn the engine on but doesn't do it once I have the engine running but it happened a few times before that when the engine was running as well.  Also, the low battery noise is just from me starting the bike a bunch of times as I was trying to diagnose the problem, or re-starting at every other stop light when it was cutting out.
I'm guessing I have a loose connection somewhere and when the wheel is turned some which way, the connection gets disconnected.  It was dark and I didn't have time to inspect things last night but what component/connection would make it lose power completely like this?  Where should I start?
Here is a video:
http://www.youtube.com/watch?v=BIu7pijtFO8
Re: Power cutting out when wheel is turned ??
« Reply #1 on: October 23, 2013, 01:25:54 PM »
Are you talking about just the light cutting out, not the motor?
My lights flicker sometimes under similar circumstances.  I figured I would track it down when I re-do my Windjammer hookup, as I was blaming that.  But you don't have a 'Jammer.
apaiva
« Reply #2 on: October 23, 2013, 01:42:13 PM »
no, not just the lights. The engine dies as well as the headlight and dials/dashboard lights.  In the video it only happens when electrics are on and engine isn't running, but other times it happened with the engine running and everything went dead. I would then move around the handlebars and dash came back to life and I was able to start the bike again.
apaiva
« Reply #3 on: October 23, 2013, 01:43:49 PM »
someone else suggested they thought it might be something with the key ignition unit since everything goes completely off, not just the engine.
« Reply #4 on: October 23, 2013, 02:44:00 PM »
It  could be a loose or semi broken ground connection as most all the dash indicators share the same brown ground wire - but as it seems your headlight is cutting out also, that seems more like a bad connection to/from the ignition switch _I'd start with the red wire going to that (should be +12V) and other switch poles and functions get their power from that.
apaiva
« Reply #5 on: October 27, 2013, 02:47:13 PM »
i figured it out. it was really stupid. just a bad connection at my battery. :P
