Author Topic: Had a bit of a braking scare  (Read 1200 times)
« on: October 21, 2013, 07:50:56 AM »
Out riding this weekend and had a cage driver pull out in front of me from a side street. I hit the brakes hard expecting to have to fight a skid. Instead I slowed a bit and then nothing. Almost like I had no brakes at all. Luckily the amount of slowing I did was enough to avoid the idiot but when I got stopped I looked and found brake fluid all over the right side caliper and disk.
I was only a few miles from home so I was able to limp home on back streets using the rear brake. I started checking and found most of the brake fluid gone and when I squeezed the lever brake fluid was coming out between the two halves of the caliper housing near where the brake line attaches.
The weather was too nice so I took a caliper off my parts bike, cleaned everything up, installed a new set of pads, bled them and got back out on the road.
My question is what went wrong? I have already ordered a Brembo rebuild kit but should I be worrying about the other side?
Re: Had a bit of a braking scare
« Reply #1 on: October 21, 2013, 07:59:55 AM »
It sounds like the o-ring that seals the fluid passageway between the caliper halves let go.
The ATE rebuild kit I got from motobins did not come with this o-ring.
There is a thread in the FAQ section on the o-ring.  This is for the ATE caliper, but according to Julio's thread on the difference between the calipers, the o-ring is the same.
Ian,
You'll need to source locally an EPDM (Ethylene-Propylene-Diene-Monomer) material o-ring for it’s resistance to high heat along with its properties to resist glycol based fluid exposures.
Size: 0.41"OD x 0.21"ID x 0.10"W.
-Mike V.
Offline Julio A.
« Reply #2 on: October 21, 2013, 12:28:52 PM »
The o-ring is squeezed between two metal pieces, and is held in place snugly in a groove. i really can't see a way for it to rupture. Even if the rubber had hardened through time, it should have still sealed fluid in as it is a non moving part.
You may want to open up that caliper to see what went wrong. The two halves may be coming apart.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #3 on: October 21, 2013, 12:30:48 PM »
Can't see how it could be anything else. First time I've heard of it though. It'll be interesting to see if the correct O ring is in there.
« Reply #4 on: October 21, 2013, 02:57:37 PM »
Well done for dodging the bullet.
You can always go down to one disc!
Rev Light.
« Reply #5 on: October 21, 2013, 04:00:41 PM »
Julio, non moving parts (most seals are stationary) can give way just as well as those that move... and although this o-ring doesn't move, it is subjected to hydraulic pressure.
I agree that he should pay close attention to the caliper bolts when disassembling, but if they are snug and the leak is indeed from between the caliper halves I can see no other culprit than the o-ring.
FWIW, mine were so worn down I thought them washers... reinstalled and still holding.
