Author Topic: Advice on Disc's  (Read 2685 times)
Advice on Disc's
« on: August 29, 2013, 02:25:52 PM »
Can anybody let me know what they think the condition of my disc's are?
They look a little shot to me, but hey, what do I know, I'm still learning... ::)
Re: Advice on Disc's
« Reply #1 on: August 29, 2013, 02:44:22 PM »
Only way to know for certain, is to measure the thickness of the rotor, the minimum is .180 in., I think that works out to 4.5 mm .
I would say on average, around 60-70,000 miles (98,000-115,000 km) of use .
« Last Edit: August 29, 2013, 03:17:47 PM by Bob_Roller »
« Reply #2 on: August 29, 2013, 02:57:05 PM »
If you are thinking about the ridges that is normal to some extent. It's due to the hole pattern not overlapping. My discs showed that pattern visibly at 6000 miles from new although now at 18000 miles the variation in thickness is still very small. Haven't measured it but it feels like just a couple of thou.
As Bob said if they pass min thickness and there are no cracks they should be fine.
« Last Edit: August 29, 2013, 03:08:27 PM by bhodgson »
« Reply #3 on: August 29, 2013, 03:55:36 PM »
Minimal thickness in millimetres is stamped on the ridge somewhere. It is mandatory.
I also think it is 4.5 mm thick.
Measure on as much place as you can. They wear in a strange pattern and you'll find some place way below 4.5 mm when others are at quite factory thickness value.
If in doubt, change the rotor. Your life may depend on it... And it's worth more than one or even a couple of rotors... Just my 2cents...
« Last Edit: August 29, 2013, 03:56:20 PM by georgesgiralt »
« Reply #4 on: August 29, 2013, 04:04:16 PM »
Thanks Guys,
What these for an upgrade?
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=20&Ct=HA&SbCt=BA_15_20_HA_45
The EBC replacements.
« Reply #5 on: August 29, 2013, 05:43:49 PM »
Both EBC and Spiegler offer excellent quality brake disc replacements.
« Reply #6 on: August 29, 2013, 06:35:10 PM »
I've got the EBC steel semi-floating rotors on my '81 R65, along with the graphite pads .
No noticeable difference in dry road braking, but wet condition braking is greatly improved .
Also no brake squeal .
A lot more 'cost effective' over OEM rotors .
« Reply #7 on: August 31, 2013, 10:58:26 AM »
Thanks Monte and Bob
fbenach
« Reply #8 on: September 20, 2013, 01:51:48 AM »
Bob, do you know what the thickness is on a new set of rotors?
Mine are 5mm right now, but I would like to know how is that compared to a brand new pair.
Thanks!!!
« Reply #9 on: September 20, 2013, 07:50:46 AM »
I can check when I get home this afternoon when I get home from work .
I don't think they are much thicker than 6-7 mm when new .
« Reply #10 on: September 20, 2013, 12:26:02 PM »
I would wait to see how they perform before changing them, mine look similar but they are fine in operation. I would stay away from the solid replacement,
Have a look at these 3rd one down or 5th......
http://www.james-sherlock.co.uk/component/virtuemart/?page=shop.browse&category_id=905
« Last Edit: September 20, 2013, 12:27:50 PM by Lucky_Lou »
« Reply #11 on: September 20, 2013, 12:36:07 PM »
5 mm is good. Min thickness is 4.5 (stamped on the original discs)
« Reply #12 on: September 20, 2013, 05:35:12 PM »
I just measured two rotors from two different manufacturers, one is an EBC semi floating rotor 5.2 mm thick .
The other is an aftermarket semi floating stainless rotor that was installed on an OEM hub or carrier, thickness, 5.2 mm .
I don't know what an OEM rotor has as an original thickness .
The original rotors on my '81 R65 got down to the minimum thickness on the high spots at 72,000 miles, 118,000 km .
So unless you don't like the rotors for some other reason, they should be good for awhile yet .
fbenach
« Reply #13 on: September 21, 2013, 01:11:31 AM »
OK, thank you guys for the feedback!!! I kinda think there's some time to save for new rotors then!!!
Regarding the EBC semi floating units... if I wanted to go for them, as long as they seem to be a little more effective on wet braking, what changes do I have to make on my bike? Do the (double) ATE calipers work with those?
Sorry if it´s a dumb question, but I would love to get that extra security on rainy season, which is almost 7 months down here!!!
Take care
« Last Edit: September 21, 2013, 01:14:18 AM by fbenach »
« Reply #14 on: September 21, 2013, 07:55:37 AM »
No changes are needed for the EBC rotors .
There are different rotors for the twin shock R65's, the snowflake wheel needs a deeper dish hub than the LS version, the snowflake wheel is narrower than an LS wheel at the hub .
