Author Topic: Front disc replacement  (Read 2745 times)
Re: Front disc replacement
« Reply #15 on: September 11, 2013, 02:46:50 AM »
Picture of brake config:
« Reply #16 on: September 11, 2013, 02:53:11 PM »
Hello !
If you do the modification, bear in mind that the right side Brembo caliper has larger mounting holes than the left one. So you also need the sleeve which goes into that hole (and has a spacer build in to center the pads on the discs so it comes in various thickness).
Offline led
  • More than two cylinders is not a bike...
« Reply #17 on: September 13, 2013, 12:59:07 AM »
Awesome replies everyone.
I can still get the master cylinder from the same bike as well as the splitter and brake lines. I will like to go with braided lines but I still need to find either a brake specialist or hydraulic shop to get pricing.
I think I will look for a R65 rotor and solve that problem.
Cheers from sunny SA
led
1978 BMW R45 (vin nr 57)
198.. BMW R65 Landspeed racer called Leftover
1976 BMW R100s 4valve Krauser heads
HESIMEUSTIC
« Reply #18 on: September 21, 2013, 05:51:46 PM »
Nice bike!
