Author Topic: Electrical issues  (Read 3001 times)
vontresc
Electrical issues
« on: August 04, 2013, 10:57:43 AM »
So I was riding home last night when the bike died. Turns out that the battery was dead. I'm figuring that I was running off of the battery and that I'm not charging the system. The weird thing is that I did not see the generator light come on.
Any suggestions as to what may have failed? Generator diode board something else?  I hate electrical troubleshooting so some tips on where to start would be greatly appreciated.
Re: Electrical issues
« Reply #1 on: August 04, 2013, 11:18:05 AM »
Does the 'GEN' light come on when the key is in the run or on position ??
An open rotor, or the 'GEN' light circuit may be open as well .
Need todo a bit of troubleshooting on these circuits .
« Reply #2 on: August 04, 2013, 02:52:46 PM »
Easy things first!
Check the GEN lamp for good/bad.
Charge the battery. Start the engine and bring the revs up to 3500-4000 rpm. Using a VOM, check charging volts at the battery.
Do that "free" stuff, then report back in with results. We can then offer suggestions to get you fixed up and rolling again.  [smiley=thumbup.gif]
« Reply #3 on: August 05, 2013, 12:15:40 PM »
When my voltage regulator failed such that it would not allow any charging to reach the battery, my generator light did not come on.  Test it by bypassing the regulator -- unplug it and use a jumper wire.  Details on Snowbum's page.
« Reply #4 on: August 14, 2013, 09:36:34 PM »
Believe it or not, if the Gen light bulb is burned out, your battery will not be charged by the alternator.  It is a design feature of the Bosch Alternator system.
Good luck.
fbenach
« Reply #5 on: August 15, 2013, 01:39:57 AM »
Good thing to know!!!
Thanks!
« Reply #6 on: August 15, 2013, 01:50:19 PM »
AND old MG Lucas systems...  ::)
I've had two Airheads with rotors that opened up...
« Reply #7 on: August 15, 2013, 02:57:44 PM »
No response from Mister Vontresc since his original post of 04 August. Guess he got it sorted 'cause we're just talking to ourselves. Good talk,yes, but it would be nice to get some sorta response as such. ::)
« Reply #8 on: August 15, 2013, 11:00:45 PM »
Closed threads are happy threads.  But on a positive note, at least fbenach learned of the gen light woes (maybe he too can be praised by Ausherman one day).
There's a reason they call them "the prince of darkness"  ;D
« Reply #9 on: August 16, 2013, 07:56:09 AM »
OK, Luca... Are you on Boxerworks, too?  ::)
« Last Edit: August 16, 2013, 07:56:30 AM by montmil »
« Reply #10 on: August 16, 2013, 08:54:15 AM »
nope, just R65.org.  I remember you posting about the Ausherman praise you got.
I was on VN750.com as bazooka_luca and now I'm on Miata.net as 650Boxer_Twin
Gotta say, this is the best forum I've ever visited.
vontresc
« Reply #11 on: August 16, 2013, 06:22:26 PM »
Sorry, I've been stupidly busy the last week and a half. I finally got to it this afternoon.
So the bulb is ok (Thanks to the diagnosis from Snowbum). I tried jumping the VR, but got no charging light.
I only got about 1.5 volts when I measured the voltage at the gen (B+ on the Diode Board to D- on the alternator)
I did pull the brushes, and they are pretty worn, and in the process of playing with them I managed to break the wire at the solder joint. Gonna have to redo that anyway, so I'll sto by the local Beemer shop and pick up a new set of brushes (77+k miles on the bike so it's probably time anyway.
I'll report back when the alt is back together
Pete
« Reply #12 on: August 16, 2013, 07:17:39 PM »
While you have the brushes out check continuity on the rotor...
« Reply #13 on: August 17, 2013, 07:58:39 AM »
[size=18]+[/size] [smiley=thumbup.gif]
« Reply #14 on: August 23, 2013, 04:59:52 AM »
Love it!
The knowledge just keeps on coming...
I'm like a sponge, just soaking it all in, it's amazing how much you can pick up, a big thank you to all the "sage's" on here.
Chris
