Author Topic: Front Disc Rotor  (Read 1399 times)
Offline decorn33
  • Loving my R65
Front Disc Rotor
« on: July 09, 2013, 10:16:09 AM »
On a recent weekend trip from New Jersey up to the Rhinebeck area in upstate New York I noticed that my front brake was starting to shudder when applied, so when got home I changed the rotor and pads out for new ones.  Looking at the old rotor I saw stamped in the rim of the casting "MIN 0.18".   By any chance does this mean that these rotors can be turned down to resurface them to a minimum thickness of 0.18?
1984 R65
Re: Front Disc Rotor
« Reply #1 on: July 09, 2013, 10:29:05 AM »
Usually with the deep grooves that develop in the rotors, if they are machined to remove them, they are too thin for safe use .
My '84 LS had the rotors machined by a previous owner, I found 13 cracks between the holes in the rotor surface between the two rotors .
« Reply #2 on: July 09, 2013, 11:08:25 AM »
I have just had a similar issue with my "K" I was advised that the discs are too thin to be ground so I got a new to me replacement on fleabay
« Reply #3 on: July 09, 2013, 12:28:11 PM »
The information stamped on the rotor indicate that this thickness it the absolute minimum.
If you measure your rotor at the thinnest point, you'll find them under the 0,18 "
If the spacers are in good shape and not warped, you can buy new rotors and affix them to the spacers (on my R65, the riveted original rotors were replaced by screwed rotors... )
This is cheaper but may make you unhappy because the steel is not the same (sometimes cast iron) and braking will change.
Offline decorn33
  • Loving my R65
« Reply #4 on: July 09, 2013, 01:38:21 PM »
Thanks for the information. It was worth asking.  I checked on Moto-Bins and they want $350 for a new rotor and spacer combo.  I had a new one on the shelf for a few years. Glad I did.
1984 R65
Offline Matt Chapter
  • <insert witty remark here>
« Reply #5 on: July 09, 2013, 02:02:11 PM »
Don't forget that spiegler can "refurbish" your rotor if you send it to them.  cheaper than oem, plus a few other benefits such as drilling and semi floating options.
'04 R1150 RT ~41000 miles
