Author Topic: Tire pump?  (Read 1221 times)
Offline davidpdx
Tire pump?
« on: June 28, 2013, 12:18:21 PM »
Has anyone found a hand tire pump that work well with snowflake wheels? Will the one being sold on ebay as a replacement for the OEM one work? Thanks
1984 R65 60K+
1946 Triumph Speed Twin
? Hunter S. Thomps
Re: Tire pump?
« Reply #1 on: June 29, 2013, 06:47:43 PM »
A number of the bicycle pump ones with wide solid heads won't fit in the tight space where the valve is, especially on the front wheel.   I had an old one which broke this year and am on the lookout for a replacement, too.
stbrown
Re: Tire pump?
« Reply #2 on: June 29, 2013, 06:58:50 PM »
I have a Lezyne pump that I use on my bicycle as well as the R65.  These pumps are small, very reliable, and attach via a short rubber hose.  You can get into almost any small space with that thing.
Steve
quixotic
Re: Tire pump?
« Reply #3 on: July 01, 2013, 06:03:35 PM »
I have a Lezyne pump that I use on my bicycle as well as the R65.These pumps are small, very reliable, and attach via a short rubber hose.You can get into almost any small space with that thing.
Steve
I concur.  And they're designed so that minimal effort is required to get high psi's.
Re: Tire pump?
« Reply #4 on: July 01, 2013, 08:36:25 PM »
Those lezyne pumps look quite handy - and would be useful on my mt bikes, too!   I'm going to look into the dual presta/schrader models for that purpose.   Any particular model you recommend?
Offline Matt Chapter
  • <insert witty remark here>
Re: Tire pump?
« Reply #5 on: July 02, 2013, 01:09:18 PM »
Consult your local mid - high end bicycle shop.  I got the one i use for my mountain bike, (and the kids' bikes) from a shop for about 25$.
It's still not as fast as the regular stand pump, so I'm going to get one of those sideways adapters that mess up your wheel balance ;) for the beemer.
'04 R1150 RT ~41000 miles
Offline davidpdx
Re: Tire pump?
« Reply #6 on: July 02, 2013, 06:56:05 PM »
Just went out and picked one up today. Hope I never have to use it as it is small enough that it would take a long time to air up a tire but it sure beats walking. Thanks for letting me know about this. The Forum comes through again!
1984 R65 60K+
? Hunter S. Thomps
jcsaintp
Re: Tire pump?
« Reply #7 on: July 04, 2013, 07:32:07 AM »
I ended up getting a 'replacement BMW pump' made by Schrader-Autoventil from RePsycle BMW for around $25. It fits securely between the lugs underneath/beside the seat. The head of the pump is too large to fit directly on the air stems so I purchased a short extension from NAPA. Well made and less than $10.
Using this set-up a bit like work but better than an under inflated tire.
