Author Topic: Parking light  (Read 1655 times)
Parking light
« on: March 30, 2013, 12:38:56 PM »
Can anyone tell me if the small parking light inside the headlight shell stays on when the headlight is on. I am looking for a convenient light/power source for my new speedo.
Re: Parking light
« Reply #1 on: March 30, 2013, 01:00:17 PM »
Yes it does.
Whether it's a US or UK Switch, Position 1 is parking light on (terminal 58) and it remains lit except for position 2 on the UK switch which is ignition on with no lights.
« Last Edit: March 30, 2013, 01:10:43 PM by bhodgson »
Re: Parking light
« Reply #2 on: March 30, 2013, 01:31:32 PM »
Thanks Barry! That is one less set of wires I have to route into the headlight shell since they are part of the same bundle as the main headlight wires.
Re: Parking light
« Reply #3 on: March 31, 2013, 03:34:44 AM »
Why don't you use the original tacho light wire ?
It should be right where you intend to use it ... Maybe you'll have to change the terminal, but.... not a big deal ?
Re: Parking light
« Reply #4 on: March 31, 2013, 04:39:57 AM »
The headlight shell I am going to use has a standard 7" headlight that does not have a place for the parking light. Since the wires are already there and are not being used it seems like an ideal solution.
RSMike
Re: Parking light
« Reply #5 on: April 07, 2013, 02:57:07 PM »
nice headlight, whats the source?
Re: Parking light
« Reply #6 on: April 07, 2013, 03:44:55 PM »
Hi Mike. The headlight shell was found at a motorcycle flea market after a long hard life. It is from a 1957 Puch Twingle and was found as just the shell. I found an aftermarket headlight and modified the mount and trim ring to fit. The yellow lens is from a transparent paint by Duplicolor called Metalcast. It is supposed to simulate anodizing when sprayed over chrome but works great on the inside of the lens.
wa1udg
Re: Parking light
« Reply #7 on: May 01, 2013, 10:45:28 AM »
What's the purpose of the yellow?  Even the French have given up on their yellow headlights.
Re: Parking light
« Reply #8 on: May 01, 2013, 11:05:52 AM »
I could say it is because being different it makes it stand out in traffic and yellow is the universal color for caution. Or I could say it is because it appears brighter at night as our eyes lose sensitivity to bluer wavelengths at night.
But the real reason is that I think it looks cool.  ;D
Dizerens5
Re: Parking light
« Reply #9 on: May 01, 2013, 02:35:02 PM »
Headlight bulbs were yellow in France until about 20 years ago. They were introduced in the 1930s I believe as they were said to be better in the coal-smoke mist of those days.  Don't know if that was ever true. Btw is there any easy way of fitting a 7-inch light unit in the R65 headlamp shell?
RSMike
Re: Parking light
« Reply #10 on: May 01, 2013, 03:00:07 PM »
wa1udg
Re: Parking light
« Reply #11 on: May 21, 2013, 08:21:11 AM »
ANyone really interested in automotive lighting ought to look at the DanSternLighting site.
Re: Parking light
« Reply #12 on: May 21, 2013, 09:53:45 AM »
That really is an excellent site. Discovered it some time back.
