Author Topic: How to run cables  (Read 957 times)
surfermac
How to run cables
« on: April 07, 2013, 06:35:10 PM »
Hi All,
I joined up a few years ago with the intent of, among other things, learning all I could about my new to me 1981 R65.  Then I bought an Airstream travel trailer.  Well, finally back to cleaning the bike up after 2 years of Airstream reno!  As part of my R65 update, I bought new choke and throttle assemblies.  My question is, how to run the cables up to through the handlebars? Any pictures, diagrams, etc. would be greatly appreciated.  Thanks, Chris
Re: How to run cables
« Reply #1 on: April 08, 2013, 12:49:11 AM »
Hello !
No rocket science here. Just place them in a way they are supple, do not tie them down to the frame and check that when moving the handlebar from one side to the other the carbs don't get accelerated.  Be logical, do not bend them hard, and it should be good.
They will move around but that's normal.
The only trick to know is to assemble the jointer boxes first otherwise you won't have enough cable play. I put Teflon based grease liberally into the jointing boxes to prevent water from entering and rusting the cables. I got the grease from a bicycle shop and it is said to be safe on plastics.
RSMike
« Reply #2 on: April 08, 2013, 01:59:39 AM »
surfermac
« Reply #3 on: April 10, 2013, 06:32:02 PM »
That's a great help.  Thanks very much for pointing me in the right direction.
Offline flybot
« Reply #4 on: April 11, 2013, 05:46:15 PM »
If you still need pics, Ive got a few from my '83 R65 restoration that I took while tearing it down that show the cable routing. Im not sure how different those years are though.
1983 R65
