Author Topic: Alternate brake caliper for a '79?  (Read 773 times)
Armen
« on: April 11, 2013, 05:15:45 PM »
Any semi-bolt-on calipers out there for a '79 single disc brake? Mine needs lots of love. Might make more sense to replace/upgrade it.
Not asking permission, only information.
thanks,
-Armen
Re: Alternate brake caliper for a '79?
« Reply #1 on: April 11, 2013, 05:26:06 PM »
Brembo calipers from the later year R65's will bolt right on and parts are available, unlike the ATE calipers .
If I remember correctly, the early K75's had the same Brembo caliper, but I would check on that before purchasing one .
I believe that the dimension between bolt centers are 108 or 109 mm .
« Reply #2 on: April 11, 2013, 05:26:55 PM »
The Brembo used on the later R65 is near identical to the ATE and perhaps more commonly available.
Armen
« Reply #3 on: April 11, 2013, 05:37:35 PM »
Thanks!
