Author Topic: New to me Oil filter Source.  (Read 919 times)
« on: April 08, 2013, 10:47:30 PM »
I got got caught out doing an oil change with out a spare filter on the shelf.  (Monday)
After calling about I found Napa had the bendy filter for about $10.  The NAPA number is PS4945 and includes the $5000 dollar o-ring, a shim, filter cover gasket (which I throw in the trash) and a oil drain washer.
When I picked up the filter, the fine print on the side said basically "made by Wix".  Which set off my alarm bells because the last Wix filter I tried had hard plastic ends that wouldn't fit inside the oil filter canister and I ended up throughing it away.
I happy to report that Wix has changed the end to a softer rubber material and it fits perfectly.
With the $2 off the Valvolene VR-1 Racing oil at Autozone I did the whole change for about $20.
Not bad  8-)
« Last Edit: April 08, 2013, 10:49:00 PM by Semper_Gumby »
Re: New to me Oil filter Source.
« Reply #1 on: April 09, 2013, 08:32:27 AM »
Not bad at all, Bill. Saved you some beer money and that's always a good thing. [smiley=beer.gif]
