Author Topic: 1979 Front Rotor  (Read 3705 times)
pastafasool
1979 Front Rotor
« on: December 15, 2012, 09:52:40 PM »
I have a '79 R65 with single front rotor and ATE caliper. Having a very hard time finding a replacement rotor. Bike came without it, it was a parts bike. Even EBC couldn't give a positive answer, saying their listing starts with the '81 model.   Has anyone found the right aftermarket rotor for this year ?
thanks
Re: 1979 Front Rotor
« Reply #1 on: December 16, 2012, 03:15:30 AM »
Motobins claim their Grimeca disc Part No.20300G fits R45/65 78-84.
I'd get them to confirm the offset is correct. I tried to measure mine for you and although it's not easy to get an accurate figure with the disc on the bike I make it approx. 40mm.
http://www.motobins.co.uk/bmw-parts.php
« Last Edit: December 16, 2012, 03:23:41 AM by bhodgson »
« Reply #2 on: December 16, 2012, 05:05:56 AM »
Hello !
I've seen bikes where only the disk has been changed. The rivets have been replaced by screws never seen before (Allen head but spherical shaped heads, and not protruding a bit on the other side they looked like a hot rivet of the 19th century but with an Allen imprint). the disk where cast iron so rusty after a rain.
Maybe something to investigate ? (the support part is specific to the R65 I think so keeping them is a good thing )
pastafasool
« Reply #3 on: December 16, 2012, 10:39:51 AM »
Barry-thanks for trying to measure the offset. EBC has 2 possibilities,
identical except for offset & thickness. One is 35.8 mm and the other 47.8 mm. I also have a local shop, Beemer Barn in Johnson Creek, NY, looking.
Red_Hen
« Reply #4 on: December 16, 2012, 11:12:06 AM »
I've had very good experience with Spiegler Performance - they know BMW's!
« Reply #5 on: December 16, 2012, 11:49:10 AM »
I just measured the rotor on my '81 R65 and a rotor off of an LS .
The snowflake wheel rotor is 48 mm from the outer surface to the surface that contacts the wheel .
The LS has a dimension of 37 mm .
« Last Edit: December 16, 2012, 12:18:04 PM by Bob_Roller »
« Reply #6 on: December 16, 2012, 02:18:26 PM »
Barry-thanks for trying to measure the offset. EBC has 2 possibilities, identical except for offset & thickness. One is 35.8 mm and the other 47.8 mm. I also have a local shop, Beemer Barn in Johnson Creek, NY, looking.
I measured 40mm from the wheel hub to the inner surface of the disc so measuring as Bob did to the outer surface would make it match with 47.8mm.
I believe the LS discs have a smaller offset due to a wider rim width.
« Last Edit: December 16, 2012, 02:18:50 PM by bhodgson »
« Reply #7 on: December 16, 2012, 11:18:16 PM »
The LS disk is the same as all the 'normal' bigger beemers. The snowflake R65 disc is also used on the R80G/S 1981-86 and the R80ST. That ought to make it a little easier to find.
I've also heard of using the shallower disc and machining up a spacer disc with longer mounting bolts.
« Reply #8 on: December 17, 2012, 05:01:44 AM »
I have an ebc disc on the front of my 1979.  So you should not have an issue.  Just take the 1981 ebc disc.
I have also updated my 1979 to take Brembo brake as well, so that is also an option.
I have not had a good experience Grimeca - I had a pair and did not get 10,000 miles out of them before they both warped to the point that they would not pass an MOT.
having said that, I have not yet covered that sort of mileage with the single EBC.
Rev. Light
« Last Edit: December 17, 2012, 05:05:32 AM by steve_hawkins »
bruce_launceston
« Reply #9 on: December 17, 2012, 05:38:58 AM »
'Braking' an Italian company make brake rotors that bolt to the original carriers, they supply all the screws, washers and nylock nuts required.
It was an easy job to grind the end off the original rivets and punch them out before bolting up the semi-floating rotors.
They even supply 2 sets of 5mm bolts in different lengths to suit the brake carriers of the LS and the other BM models that the rotor can fit.
If you look them up on the web you will see that they have a new range of rotors that look less like the factory ones, I think they were slotted or maybe a wave pattern as opposed to being drilled in a similar patttern to the OEM ones.
« Last Edit: December 17, 2012, 05:43:48 AM by bruce_launceston »
« Reply #10 on: December 17, 2012, 07:21:54 AM »
I just looked up a disk on the website that Bruce mentioned. Seems like a good price although this is the fixed version. The floating disc is another 50 Euros.
http://www.braking.com/catalogue/dettaglio_prodotto.php?codice_articolo=BW01FI
« Last Edit: December 17, 2012, 07:37:59 AM by bhodgson »
« Reply #11 on: December 19, 2012, 06:14:14 AM »
pastafasool
« Reply #12 on: February 22, 2013, 07:59:03 AM »
Bob and Barry- your info was correct. Our non-LS 1979 R65 took the EBC # MD606LS (larger offset) .  After receiving the MD602LS (smaller offset) we finally received the right one and it's perfect.  EBC's "LS" has nothing to do with BMW's "LS", in case anyone is confused by that. Thanks again for the help.
fbenach
« Reply #13 on: February 23, 2013, 01:37:11 AM »
So, 79 model takes the regular disc and LS take the narrow disc. Did I get it correct?
What about dual discs?
My bike has two ATE units, but always wondered which disc fits by EBC.
« Reply #14 on: February 23, 2013, 08:00:36 AM »
The rotors are the same for the OEM 'snowflake' wheels of all the years of R65's .
The wheel, not the caliper is the determining factor .
The ATE and Brembo calipers can be used on any R65 .
The LS model and the monoshock bikes take the shallow discs .
« Last Edit: February 23, 2013, 08:03:37 AM by Bob_Roller »
