Author Topic: 82 R65LS Coil  (Read 959 times)
jgp1854
82 R65LS Coil
« on: January 17, 2013, 08:30:51 AM »
Getting ready to install a new dyna coil, is it recommended to use some "dielectric lube", on the spark plug wires going into the new coil?
Thanks
jgp
Re: 82 R65LS Coil
« Reply #1 on: January 17, 2013, 08:42:24 AM »
Yes, it makes it a bit easier to get the leads all the way into the coil .
Also, when you put the wires on, make sure the electrical hardware doesn't touch the steel laminate mounting, one of them is quite close .
I've put insulating tape on that connection .
The outboard most wire, needs to be pointing up, if you put it on with the wire coming out at a 90 degree angle from the coil, it will contact the fuel  tank .
« Last Edit: January 17, 2013, 08:43:08 AM by Bob_Roller »
