Author Topic: Oil filled manometer  (Read 772 times)
« on: November 03, 2012, 04:42:01 PM »
Used my homemade oil filled manometer today .
I have to say, that it worked great, compared to the Twinmax synchronizer I have been using .
I used BMW 7.5 wt fork oil, good contrast to the white .
One thing I did notice, after you make an adjustment, wait 30 seconds or so, otherwise, you'll be adjusting constantly .
Constructed it from scrap materials and hardware that I had accumulated at work .
If you make one yourself, use small diameter clear tubing, less oil used .
Performing a carb synchronization on the '82 LS, after a complete carb rebuild .
Still getting a bit warm in the garage .
Another clear, sunny, warm day in the northern Sonoran desert .
Performed a carb synch on the '81 R65 as well .
« Last Edit: November 03, 2012, 05:06:43 PM by Bob_Roller »
Re: Oil filled manometer
« Reply #1 on: November 04, 2012, 03:50:07 AM »
It always amazes me how a home made manometer reacts to the smallest possible adjustment. Nothing is more sensitive.
Good to see you can still get things to grow in that climate Bob.
« Reply #2 on: November 04, 2012, 09:01:30 AM »
I, too, used "official" BMW 7.5 fork oil. The purple color looked pretty cool and was easy to see.
After a couple months, the fork oil lost it's purple.  :(
« Reply #3 on: November 04, 2012, 11:48:57 AM »
ATF is a similar viscosity and bright red. Seems to hold it's color for years.
