Author Topic: R65 1981 fork gaiters  (Read 1570 times)
Offline NorR65
« on: November 01, 2012, 02:29:48 PM »
I have to remove the long gaiters and instead use the small rubber dust boots. Inside the dust boot I have to use felt seals.
My question: do I have to oil the felt seal?
Thanks
Re: R65 1981 fork gaiters
« Reply #1 on: November 01, 2012, 02:31:39 PM »
You can put some fork oil on the pieces of felt .
« Reply #2 on: November 01, 2012, 02:36:32 PM »
The oiled felt is a bit easier to fit into the dust caps. It's also the last bastion of dusty grit defense.
« Reply #3 on: November 01, 2012, 05:04:53 PM »
I don't add oil to the felts as I see one of their functions is to absorb any oil that gets past the seals and they can't do that if already saturated. A slight trace of oil always does seem to get past on mine even though it has new seals and perfect stanchions. On the other hand it would not be a good thing if new felts caused any significant drag so maybe a trace of oil on the surface would be OK.
« Last Edit: November 01, 2012, 05:06:18 PM by bhodgson »
« Reply #4 on: November 01, 2012, 05:11:25 PM »
I generally dip my finger in some fork oil and give new felts a bit of a wipe with the oil - don't try to staturate them, but enough so the go in the slot they are suppsed to and  slide/wipe freely.
« Reply #5 on: November 01, 2012, 08:45:08 PM »
Manual says the felts should be lightly oiled.
Offline NorR65
« Reply #6 on: November 02, 2012, 09:55:59 AM »
Thanks
I will use fork oil. Now I am ready to remove the forks.
