Author Topic: Bean Can Maintenance  (Read 908 times)
Red_Hen
« on: October 22, 2012, 05:10:05 PM »
Hi Gang,
Yesterday Tina went into the hanger for the winter.  After pulling her battery to store inside, I removed the beancan.
I removed the inspection cap and the top cover and she looks pretty clean inside.  Wondering if there is any maintenance needed? I realize the bike is 30 years old but since the can is "sealed" is there any maintaining needed?
What are your thoughts?
Online Bob_Roller
Re: Bean Can Maintenance
« Reply #1 on: October 22, 2012, 05:58:21 PM »
About the only thing in there, that may need lubrication, is the pivot point for the centrifugal weights of the advance mechanism .
Sticking weights are about the only issue that i have heard  as being common problem with the 'bean can' .
« Reply #2 on: October 22, 2012, 06:15:12 PM »
Ken, you can pop open the oval-shaped cover on the side and see the weights and springs, etc. Small needle oiler and a drop would keep you lubed up for a long time.
Truth be told, most folks blame poor idle hi revs on sticking weights but the problem is often incorrect idle mixture screw adjust.
« Last Edit: October 22, 2012, 07:04:31 PM by montmil »
Red_Hen
« Reply #3 on: October 22, 2012, 06:51:53 PM »
Thanks, guys
I wasn't having any problems with it - just wanted to confirm its condition and it looks good.
A friend sent me a spare Hall sensor, that I'll covet when the day arrives and it's time to be replaced.
