Author Topic: Rear Set  (Read 2459 times)
luckyd20
Rear Set
« on: August 11, 2012, 02:37:48 AM »
Can anyone point me to the right direction of rear sets for the r65?
Also can you post some pictures please. Thanks!
Session101
Re: Rear Set
« Reply #1 on: August 11, 2012, 03:38:12 PM »
http://boxermetal.com/
he sells bolt on and ready to go, or you can buy the universal rear sets and bend them yourself
luckyd20
Re: Rear Set
« Reply #2 on: August 11, 2012, 10:20:56 PM »
yea i was talking to a guy there and he said since the r65 is unique, that the rear sets he makes more than likely won't fit.
Session101
Re: Rear Set
« Reply #4 on: August 12, 2012, 01:53:49 AM »
pic of the raask ones
« Last Edit: August 12, 2012, 01:54:25 AM by Session101 »
bruce_launceston
Re: Rear Set
« Reply #5 on: August 12, 2012, 06:33:44 AM »
A neater but not as rear set solution is to modify the existing mounts.
I cut and rewelded a spare set of mounts resulting in the gear side peg and lever moving back 65mm (2.5 inches) and the right side peg back about 15mm.
This leaves both pegs in line accross the bike and the same height above the floor.
The brake pedal stays unmodified but is still easily reached.
The gear linkage is a long 6mm bolt with the head cut off and a new thread cut on the other end.
I cut the flattened tip off the right side peg mount and welded it back on in a horizontal plane so thet the rubber sits correctly.
Both peg mounts bolt back on as per standard with the original bolts.
I am very happy with the result and the fact that the footpegs now line up, I have no idea why BMW offset them so far.
« Last Edit: August 12, 2012, 06:41:38 AM by bruce_launceston »
Re: Rear Set
« Reply #6 on: August 13, 2012, 02:06:34 AM »
I have RAASKs on mine.  Not as pretty/bling as some.  But they fit out of the box.  And there is a special R65 version.  You can also hang a passenger foot rest off them - but not the standard one.
They are a bit chunky and many of the parts are powder coated rather than metal finished.  But they can be spruced up and there is plenty of room for beautification.....Not that I have bothered.
Rev. Light
luckyd20
Re: Rear Set
« Reply #7 on: August 13, 2012, 12:23:34 PM »
Perfect thanks!
DgM
Re: Rear Set
« Reply #8 on: August 13, 2012, 02:31:55 PM »
Relocating foot-pegs increases riding pleasure - relief from heat of cylinder heads as well more balanced riding position.  For a BMW look - utilizing BMW parts, please refer to my posts from 9/30/10 thru 10/3/10 under heading 'footpeg relocation'.   I moved the pegs back by modifying original mountings, cut/welded rear brake pedal, threaded a cut down rear brake rod for shift (johnson) rod - used as many factory parts as possible - looks like it came off high speed Berlin assembly line (I believe BMW made about three R65 bikes a day).
Session101
Re: Rear Set
« Reply #9 on: August 14, 2012, 12:18:48 AM »
dude i want more pictures of your cafe racer, looks sweet!
Re: Rear Set
« Reply #10 on: August 14, 2012, 02:30:05 AM »
Here you go then:
« Last Edit: August 14, 2012, 02:32:02 AM by steve_hawkins »
luckyd20
Re: Rear Set
« Reply #11 on: August 14, 2012, 10:22:14 AM »
I love how you set up the indicators and speedo!
Session101
Re: Rear Set
« Reply #12 on: August 14, 2012, 04:50:20 PM »
that thing is awesome, you need a build blog so i can see how you did it, looks great, you machine that yourself?
Re: Rear Set
« Reply #13 on: August 15, 2012, 06:22:06 AM »
I just removed every thing did not need.
luckyd20
Re: Rear Set
« Reply #14 on: October 16, 2012, 09:28:04 PM »
@steve hawkins-is there any difference with a shorten subframe? Like flex or what not?
