Author Topic: 82 R65LS "which spark plug to use"  (Read 933 times)
jgp1854
« on: October 08, 2012, 08:25:28 AM »
Manual calls for Bosch W6D, I'm currently using NGK BP6ES.  What is the CW as far as which make/model of plugs to use?
jgp
Re: 82 R65LS "which spark plug to use"
« Reply #1 on: October 08, 2012, 08:34:56 AM »
I run the NGKs you mention. I have the Bosch plugs in the parts drawer. Both are good choices and, IMO, perform "all same, all same."  [size=9]-The Sand Pebbles[/size]
« Reply #2 on: October 08, 2012, 11:58:44 AM »
With non resistor versions of the Bosch plugs becoming hard to find NGK's are considered the best choice. An NGK BP6ES is the correct equivalent to the Bosch W6D
