Author Topic: Liquid Crystal Displays  (Read 828 times)
« on: July 10, 2007, 07:35:59 PM »
 I'm looking at liquid crystal displays for oil temperature and voltmeter . The only LCD that I have had on my R65 was an air temperature indicator, and the display 'washed out' in temperatures above 100 F. Is this a commn problem with all LCD's?
« Last Edit: July 10, 2007, 08:21:55 PM by Bob_Roller »
airhead
Re: Liquid Crystal Displays
« Reply #1 on: July 10, 2007, 10:38:17 PM »
Yes, though they are getting better and am sure if shielded from strong sunlight will give acceptable service (under a tinted S fairing say?!?).
I once pulled apart the speedo/tach unit on a rice cooker I had to stick a cheap digital watch face in there to give me a clock, reasoning that a year or so till I needed to change the battery was worth going to the trouble of the dis-assembly. It lasted only a few days till the display blanked out, and on only the coldest of mornings would give a meagre display till it hit sunlight or warmed up. Seems to permanently affect the display.
Bill...................;-)
