Author Topic: Fuse Block  (Read 1005 times)
Red_Hen
Fuse Block
« on: August 13, 2012, 01:40:11 PM »
I know there was a previous thread on fuse blocks for our bikes.
I added a relay for my air horn last year and now plan to add my Aux Power Plug.  I hate running another set of wires to my battery.
Which one(s) work best for our R65's?
Mine's an R65LS
darrylri
Re: Fuse Block
« Reply #1 on: August 13, 2012, 10:21:30 PM »
Not mon my R65, but my R1200ST, I installed a Fuzeblock.  Handles up to 6 circuits, each of which can be individually configured to be always-on or, through the included relay, switched.  Just wire it to battery +, - and a switched power source like the taillight.
Re: Fuse Block
« Reply #2 on: August 13, 2012, 10:29:16 PM »
This is the one I stuck under the "radio box" on my RT-P.  I think it was from Del City.  I wired in my driving lights and fogs to their own fused circuits with relays...
bruce_launceston
Re: Fuse Block
« Reply #3 on: August 14, 2012, 03:53:45 AM »
This is a simple fuse block but it doesn't have a common 'live' bar. You need to run a separate positive or jump them across.
This one has 4 fuse slots but they make them with 6 or more I think.
From memory it's a 'Narva' product.
The additional high and low beam relays were fitted when I rewired the headlight in heavy cable to try and improve the light output.
« Last Edit: August 14, 2012, 03:59:03 AM by bruce_launceston »
Red_Hen
Re: Fuse Block
« Reply #4 on: August 14, 2012, 09:47:15 PM »
If I purchase something like this could I ditch the stock fuse block with the ceramic fuses?  I'd have enough ports & could use modern fuses, correct?
http://www.easternbeaver.com/Main/Products/Fuseboxes/PC-8/pc-8.html
« Last Edit: August 14, 2012, 09:47:45 PM by Red_Hen »
Re: Fuse Block
« Reply #5 on: August 14, 2012, 10:01:20 PM »
You can eliminate the OEM fuse block with that setup .
