Author Topic: Where to mount a power plug on my R65LS  (Read 1778 times)
Red_Hen
« on: August 07, 2012, 10:09:29 PM »
Hi Gang,
Hope you're off to a good week!
Looking for ideas on mounting a power socket on my bike - something I can plug my battery tender in or for charging my cell phone.
My thoughts were as follows:
1.  Rear fender - nixed idea because mud & grime would ruin the connectors.
2.  Drill hole in side covers - really don't want to drill holes in side covers.
3.  Best idea so far is to mount power socket on a flat aluminum bar and attach the bar on each side of the frame under seat.
Open for ideas.
Thanks
KT
Re: Where to mount a power plug on my R65LS
« Reply #1 on: August 07, 2012, 10:19:35 PM »
I just have an extra-long battery tender lead set attached to my battery, and I coil the length of cable up and tuck it into the toolbox.  On long trips, I unwind the  cable and route it out from under the seat and up to my tankbag.   I have a powerlet socket adapter in my tankbag - it was intended for someone to drill a hole through their tankbag and mount it to the bag's side, but I just leave the thing inside the bag.   I plug the battery tender cable  into it and I then can plug in a cigarette-style power connector/cell phone charger in the other side of the adatper, or with another short adapter cable, a GPS (If I had one) there.   I cannot recall the vendor at the BMW rally I got this stuff from, but they gotta be advertising in either the MOA or RA magazine somewhere.... will look later this week.
« Last Edit: August 07, 2012, 10:20:48 PM by nhmaf »
« Reply #2 on: August 07, 2012, 10:33:37 PM »
I've been considering putting an OEM style power outlet on the right side of the sheet metal part of the  frame just below the seat, there are a series of holes just aft of the right rear shock absorber, that was meant for police accessories .
There was an OEM mount for one, I think it was mounted somewhere around the left battery cover .
http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=71_0579&hg=71&fg=15
« Last Edit: August 07, 2012, 10:36:46 PM by Bob_Roller »
Offline Graeme
« Reply #3 on: August 08, 2012, 06:43:00 AM »
I just bought a cig lighter socket, attached it directly to the battery with an 8 amp fuse. On the LS there's a "boot" behind the seat with a hole to thread the wires and it lies in wait within for something to plug into it. I can only envisage a 'phone; maybe a GPS one day.
I also have a battery tender attached the same way. The battery terminals aren't overloaded.
« Last Edit: August 08, 2012, 06:44:53 AM by jibbonpoint »
1985 R65 LS
raymr
« Reply #4 on: August 08, 2012, 06:51:07 AM »
Wherever you put it, I would zip tie it in place there for a little while to make sure it works the way you envision, before drilling holes and making it permanent.
bruce_launceston
« Reply #5 on: August 08, 2012, 07:05:33 AM »
The factory auxillary power outlet fits in front of the shock absorber and is held in place with the shock top nut as per attached photo.
It is simple to attach battery charger without opening the seat even.
These power fittings can be bought from auto electrical accessory shops along with the plugs.
I spliced a pair of these fittings into my charger cable so I can swap between battery clips for the car and the accessory plug for the bikes. My LS has the factory fitting  but I made a bracket to suit and fitted one to our Ducati.
« Last Edit: August 08, 2012, 07:09:21 AM by bruce_launceston »
« Reply #6 on: August 08, 2012, 08:22:15 AM »
Bruce, thanks for the picture, I wondered where that bracket was mounted on the bike .
I should have most of my work day free on Saturday, may make an attempt to fabricate a bracket from aluminum .
« Last Edit: August 08, 2012, 08:24:33 AM by Bob_Roller »
Red_Hen
« Reply #7 on: August 08, 2012, 03:04:30 PM »
Thanks for sharing this , Bruce
A clean install!
Red_Hen
« Reply #8 on: August 11, 2012, 04:21:20 PM »
Bruce - would you happen to have a pattern of the bracket you made?  From the picture, it looks like you took a piece of aluminum or sheet metal and cut a "L" shaped piece.
Thanks!
« Reply #9 on: August 11, 2012, 05:08:32 PM »
If you are interested, the brackets are still available from BMW, I checked on Thursday and there are 6 available in the US, for about $6US each .
« Reply #10 on: August 11, 2012, 07:28:51 PM »
Wow - if they are really only $6 that has got to be about the least expensive BMW accessory they sell!
 :D
Red_Hen
« Reply #11 on: August 11, 2012, 08:57:06 PM »
Thanks, Bob - I'm adding this to my order - ordered the throttle stop today.  Thanks!
« Last Edit: August 11, 2012, 08:58:29 PM by Red_Hen »
Crossrodes
« Reply #12 on: August 11, 2012, 09:36:13 PM »
I have one on my '79 and it is a stock item.  Here is a link to the parts diagram:
http://www.realoem.com/bmw/showparts.do?model=0353&mospid=51896&btnr=71_0579&hg=71&fg=15
Crossrodes
« Reply #13 on: August 11, 2012, 09:37:36 PM »
It fits on the frame ahead of the left hand shock.  It may or may not fit your bike.
bruce_launceston
« Reply #14 on: August 13, 2012, 06:49:57 AM »
Hi Ken, the bracket in the photo is the one that came from the factory on my R65.
The one I fabricated is a simple angle bracket on a different bike in a different location.
