Author Topic: Gen light at tick over  (Read 1099 times)
Tony_Pattison
« on: July 09, 2007, 01:55:47 PM »
the generator light comes on at tick over speed, but goes out over that engine speed.
Is this a case of replacement, or are there parts that need replacing?
thanks
Tony
Re: Gen light at tick over
« Reply #1 on: July 09, 2007, 02:18:44 PM »
That's pretty much normal operation, as odd as that might seem to someone new to BMW airhead bikes.
« Reply #2 on: July 09, 2007, 02:56:07 PM »
If it's not out by the time you reach 1200 RPM, then you start worrying...  Put a voltmeter across your battery, rev to 3500 RPM, if you have at least 13.5 - 13.6 volts then your charging system is doing it's job.
Tony_Pattison
« Reply #3 on: July 09, 2007, 04:57:18 PM »
thanks guys, another worry put to bed.
It's only there at around 1000 rpm, a fast idle and above and it's gone.
thanks
Tony
