Author Topic: IN-LINE FUEL FILTER  (Read 975 times)
MarkMod
IN-LINE FUEL FILTER
« on: July 31, 2012, 06:40:34 AM »
Can anyone tell me which way round the in-line fuel filter should be? Does it matter.
Thanks
Re: IN-LINE FUEL FILTER
« Reply #1 on: July 31, 2012, 07:51:13 AM »
It should be installed with the fuel coming in around the filter element, so you can see if there is any debris in the filter .
IN-LINE FUEL FILTER
« Reply #2 on: July 31, 2012, 07:52:45 AM »
[movedhere] Chit-Chat [move by] Bob_Roller.
Dizerens5
« Reply #3 on: July 31, 2012, 09:20:16 AM »
There should be an arrow or similar marking on the transparent casing. I have removed mine --  not able to find one small enough.The small m/c ones from Vehicle Wiring Products fit but the pressure from the bends in the fuel hose ends up bending the filter's outlet stubs and eventually they start leaking because of this. Any better ideas, anyone? Two right-angle hose connectors don't solve the problem completely and look pretty silly as well.
« Reply #4 on: July 31, 2012, 09:33:37 AM »
MarkMod
« Reply #5 on: July 31, 2012, 11:25:33 AM »
Thanks for that. The arrow on mine has rubbed away but I guess it makes sense that the fuel goes in and around the filter then through the gauze filter on the way out.
I have ordered another one tho from Moto Bins. Cost was only £2.49
« Last Edit: July 31, 2012, 03:53:41 PM by MarkMod »
« Reply #6 on: July 31, 2012, 05:53:00 PM »
What postiion does the fuel line come out of the fuel tap, 3 o'clock, or 6 o'clock ?
