Author Topic: Removing & plugging the Pulse Air and Evaporative  (Read 2730 times)
Offline jakebass12
  • double clutching diesel demon.
« on: July 10, 2012, 12:26:41 PM »
i found a couple of links explaining how to do this. here they are.
http://bmwmotorcycletech.info/pulseair.htm
http://www.webbikeworld.com/Motorcycle-technical-articles/pulse-air/
and i think i found all the parts i need to do it on motobins. here are the part numbers.(i havent got the parts to see if they actually fit but when i get them ill post on this topic if they do or not. so order at your own risk, i dont want to be responsible for you ordering something that doesn't fit.)
here are the part numbers for motobins-
timing hole plugs-11680
oil drain plugs(stainless steel)-80041s
oil drain plug crush washers-04430
screws for the vacuum take-offs under the carburetors-60280
and the washers  for the screws vacuum take-offs said it wasn't necessary.
 and when i get the parts ill take a better picture of them and post it. ;)
1981 bmw r65. 1981 kawasaki kz550
Re: Removing & plugging the Pulse Air and Evaporative
« Reply #1 on: July 10, 2012, 12:35:22 PM »
I yanked the pulse air system off both my R65s. I left the vacuum 'nipple' as-is on the carbs and sealed it off with a vacuum cap. Makes things much easier when you want to hook up your $4.00 manometer for a carb balance job. Otherwise, you'll need to keep up with the removed nipples and reinstall them for any carb tuning. Airhead simple.
Offline jakebass12
« Reply #2 on: July 10, 2012, 01:03:19 PM »
monte, what did you use to plug the hole on the cylinder? and did you notice a performance or increase of MPG when you took it off?
« Reply #3 on: July 10, 2012, 02:52:14 PM »
The holes left in the cylinders, after tossing the air hoser mess, were secured with drain plugs purchased from Hucky's. You'll need drain plugs that use an Allen wrench to secure them in place. IIRC, there was no room for a socket.
I've noticed no gain nor loss in MPG nor any seat o' the pants change in engine ops with either the '81 or '83 R65s.
« Last Edit: July 10, 2012, 02:55:34 PM by montmil »
« Reply #4 on: July 10, 2012, 03:00:03 PM »
I removed the system off of my '81 R65, in '83, no change in engine performance or fuel consumption .
The pulse air system, just puts fresh air into the exhaust, to continue burning fuel that didn't get consumed in the cylinder, to meet exhaust emission standards .
To the best of my knowledge, the counties around the Phoenix and Tucson areas are the only locations in the US, that require motorcycles to under go exhaust emission testing every year, as part of the registration renewal process .
« Reply #5 on: July 10, 2012, 10:39:01 PM »
Here's a few pics of the conversion on my R100...
Offline jakebass12
« Reply #6 on: July 10, 2012, 11:49:22 PM »
thanks for the pictures Justin.
Offline steven m
« Reply #7 on: July 11, 2012, 11:45:58 PM »
If there is no performance gain, they why take the system off?  As a purist I get it, and it looks better, but...
Steve
« Reply #8 on: July 12, 2012, 04:34:02 AM »
Thankfully we never had that system fitted in the UK but if it had been I'd be offended because it's ugly and adds weight. Perhaps more important is that any sort of after burn in the exhaust would increase temperatures unnecessarily which can't be a good thing.
« Last Edit: July 12, 2012, 04:40:14 AM by bhodgson »
« Reply #9 on: July 12, 2012, 08:00:34 AM »
Steve
This question has been asked before. The best reason for removal of the Gubmint-mandated system was provided by Justin. He stated that air injected into the exhaust valve area increased the burn of gases and also had the potential of accelerating wear and failure of the exhaust valve and seat. This concern has been bounced around on several Airhead-related forums.
Secondly, the rusty steel piping looks so much better in the trash bin.
« Last Edit: July 12, 2012, 08:01:27 AM by montmil »
« Reply #10 on: July 12, 2012, 09:09:13 AM »
I had one of the vacuum activated valves in the airbox go bad and had a vacuum leak that took a long time to find .
That's when it came off of my '81 R65 .
Offline steven m
« Reply #11 on: July 12, 2012, 10:22:38 AM »
Points well made.  It always seemed a little Rube Goldberg to me.  I'm sure it sounds better without the air injection too.  Maybe I'll pull mine, after I get through the rest of the to do list.
Steve
Offline Matt Chapter
  • <insert witty remark here>
« Reply #12 on: July 12, 2012, 11:19:04 AM »
Mine got removed when I had the motor swap done and the mechanic said "well, I figured you didn't want to pay extra for me to hook it back up!"
That my friend is why you keep getting my business, it's like you read my mind!
(Less money on motorcycle = more money on beer.)  [smiley=beerchug.gif]
'04 R1150 RT ~41000 miles
Ron_S.
« Reply #13 on: July 12, 2012, 11:54:14 AM »
Is there any reason it can't or shouldn't come off my '86 R65?
« Reply #14 on: July 12, 2012, 12:39:59 PM »
If you want it off, take it off .
Only caution I can think of, is that the metal part that is threaded into the head, may not want to come out after 26 years .
I don't know how common it is to strip the threads out on the head trying to remove this part .
You just need to plug the holes in the head and airbox and cap the ports on the carbs .
